How to pause may video recording? I can pause while playing back but can't seem to figure out how to pause a recording then resume, it just stops and starts a new clip. Please help.
The default is to start a new clip every time you press the stop button, but in settings you might be able to tell the camera to continue with the same clip provided you press record again with a set time. Not sure why you want to do this though - it's much easier to edit using small clips than very large ones.
SOURCE: Canon video camer ZR700
THIS SOUNDS LIKE MAYBE A DIRTY HEAD.. OR A LOOSE CONNECTION BETWEEN THE LCD AND DAUGHTER BOARD.. MOST LIKELY A DIRTY HEAD, TRY A CLEANING CASSETTE
SOURCE: I am trying to load my video recording to my PC
you have to also plug in the power cord at the same time.
SOURCE: How do you download video clips from a Canon FS100 camcorder?
the easier way its to go on the actual folder and copy /paste ...but ...the actual way ...is to select it just like a picture..and then download....I believe you used only the automatic download until now...but if you cancel that ...it will either open the folder prompt to ask you what to do ...just like you insert a cd...and there select open folder...and copy manually ...or ...open the manager ...select import from device ..and there look for the folders(browse) where the videos are ..it is usually a different one on the card..
...also if you cancel the initial download....you will find the camera storage (SDcard) into the My computer ...as a removable device ......act with it as any other moving from folder to folder...beware if you select cut ...this will remove from the card permanently ...the file
SOURCE: how to copy videos from canon fs100 to pc
THE SERIAL NUMBER OF MY CANNON FS 100 IS NOT ACCEPTED
SOURCE: When I transfer videos from canon fs100 into my
I also am facing the same problem. Even the videos can be played in PC, then don't give any sound at all. And I have no idea about it too. Really stuck at that point.
Another thing is; how to disconnect the camcorder from PC although I remove the hard disk of it via safely remove, as it always warn "PC connected, WHILE THE CAMCORDER IS CONNECTED TO A PC DO NOT DISCONNECT THE USB CABLE OR POWER SOURCE, CANNOT TURN OFF POWER OR CHANGE MODES" in its display LCD. So, What I am gonna do????
Actually for transfering the images and videos from your camcorder to PC is; you need to install PIXELA ImageMixer 3 SE first, which is aldy in your kit. Then, you can edit and browse the videos and images from your camcorder.
P.S: If somebody knows how to solve these, please share the solutions. Thanks!
Am I wrong to purchase that Canon FS200 because of its external audio jack(whereas others don't have that access), compact design and reasonable pricing ?
