Question about Yukon Viking 2x24 Night Vision Binocular
Hi there We have a pair of Yukon "Viking" Night Vision that needs one photo tube repaired. Would you be able to assist us? Please could you advise? Many thanks
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 94 Answers
SOURCE:
TZS-2
The voltage should be good. It is possible the Infra-red emitter tube might be at fault.
The night vision can work under a full moon, so test the vision part to make sure it is working correctly. If you have an infra red/IR remote control for your TB set, you can test the might vision using that remote to see if the night vision is working.
You can use a second working unit to see if the illuminator is actually working. The illumination is not visible light without assistance.
Jan 31, 2012 | Kalinka TZS-2 'Sova-2' Russian Night...
Unit simply does nothing when its turned on. the IR assist still works. (AN/PVS-7B/D
Letto, This PVS-7B has a generation II image intensifier tube in it. The image tube is manufactured by ITT liton company. The only way to fix this wonderful NV devise is to send to ITT Night Vision Company. They are listed in the internet. Unless you can find someone to work on it, but the really need to know what they are doing. stewbison
Mar 01, 2011 | US Night Vision Ultra PVS-7B Goggles
Left a pair of PVS7B/D's on with the pinhole lens cap in place for about 16 hours by mistake, now I see a "ghosted" permanent image superimposed over my real time image. What does this indicate?
It's called time exposure or flash over. What happen is the infiltrating light through the pen hole and a long duration will burn shadows into the micro channel plate in the generation 3 image intensifier tube.
These expensive image tubes can be repaired. Contact Itt inc or Vard Inc in Garland, TX. That about it unless you want to buy a new gen 3 image tube. Maybe $1500+. I would call around to other Night Vision Optica companies and see if the have a used gen 3 image tube. There quit a few companies in the USA that work on NV devise. Also, contact ITT and ask them they repair image tubes, maybe! stewbison
Jan 20, 2011 | Optics
I have an ATN Aries MK330 night vision riflescope. I can hardly see the reticle glow. Welcome any helpful advise on how to make it brighter
Humm! The image intensifier tube just about to go south in one leaping moment. This scope has Russian manufacture parts, image tube, ccfl, inverter, voltage multiplier, wire almos everything is Russian except maybe the the blacken aluminun tube and covers. Now, the Russian make some very good optics. I needs some parts, what do you for it. stewbison
Jan 07, 2011 | ATN Aries 330 Warrior
Green light comes on but no picture. where is best place to get repaired in scotland
Hello, most of these night vision devises are repaired by the companies that offer to sell and service. It almost impossible to find someone other than the dealer to repair them. You try Morrision Optic they have big web page on the Internet. A little warning here. These companies they sell NV devises are not necessarily the manufacture of these NV devise. Russian make a lot of these NV devises for US NV companies.
I repair them also but it hard for me to get parts, and I can make other parts if I can find some dealer that will sell me parts For a 1st generation cheap Russian image intensifier tube will cost about $175 each and sometime I can get them cheaper. GB....stewbison
Dec 07, 2010 | Yukon 28041 Binocular
Hi the ir is not working on my bushnell 26-0400,is there any way you can help (repair ?)
I had the same model, same problem. Bushnell replaced mine under warranty, If they needed to send it for repair it had to go to Russia. I guess it was cheaper to give me a new one. If its not under warranty Bushnell will send it off for you but it will cost quite a bit. My new pair lasted about 2 years with a lot of usage. Gen 1 night vision tubes do not have a very long life span. You may be better served buying a new pair of night vision binos.
Jul 08, 2009 | Bushnell 26-0400 Binocular
Name of scope . Yukon . Problem : I tried to replace a battery in the dark. Removed the wrong part by relative force . Scope damaged. Two tubes on the front of the scope one is the battery tube and th
I would strip the wires as carefully as I could and get them back together, get the 2 AA batteries back in there, and see what happens. Then go about making a permanent splice in the wires and getting the lens to stay on there, or ship it back to Russia for repairs. Or find somebody to do it. I'm sure it can be done. Hope this helps.
May 24, 2009 | Zhumell Yukon NVRS Titanium 2.5x42 Night...
Yukon spartan my pic is not clear light works but cannot get focu
Define 'clear'.
Is it blurry? Focus the scope or clean the lenses.
Is it distorted? Don't know how to fix. Especially if the lens is cracked/scratched etc.
Is it dark/snowy? Put fresh batteries in.
Do you see black spots in the tube? Don't worry, certain amount of these are quite acceptable.
Anyway: It's a night vision for pete's sake. The picture won't ever be like the one on normal binoculars.
Jan 17, 2009 | Yukon 24021 Monocular
Night owl / night vision
Unscrew front lens front of intensifier tube should have an even bronze tinted coating on glass if it is grey and blotchy the tube is degassed. common fault with this model nightvision
wayne
May 30, 2008 | Night Owl Optics Aero NOAR25 Monocular
Tasco nv 356 night binoculars
Check the HV to the tube and see if you can see any discolouration or spots on the tube - they often indicate tube failure. Many binoculars use the one power supply for both tubes as the current demand is very low. Often, one tube operation indicates tube failure, but a wire or connection could be at fault.
Nov 27, 2007 | NewCon Optik BN-5 Binocular
Yukon Viking 2x24 Night Vision Binocular Logo
141 people viewed this question
Top Yukon Optics Experts
Marvin
Marvin
John Porter
Bill Boyd
Are you a Yukon Optic Expert? Answer questions, earn points and help others
