Health & Beauty Logo
John E Heintz Jr Posted on Aug 22, 2014
Merits DL 52 i electric wheel chair, all leds flash 3 times as a error code. Battery is fully charged, then turn on wheelchair. All led are on. then when the joy stick is pushed, all leds flash 3 time
Dynamic DL 5.2i controller Model #DL50UEHS3 All LED's flash 3 times and pause, and flash three times and pause etc.
Ryan Brockman
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 34 Answers
  • Posted on Aug 22, 2014
Ryan Brockman
Contributor
Level 1:
New Friend:
Cheetah:
Answers
34
Questions
0
Helped
11432
Points
99
Make sure the manual brake isn't down.
1 Related Answer
Anonymous
  • 232 Answers
  • Posted on Oct 20, 2010
SOURCE: Merits DL 52 i electric wheel chair, all leds flash 3 times.
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Hi I have a Dynamic DL 4.2i electric wheelchair, when it is turned on the leds just flash and chair won't move .
If your Dynamic DL 4.2i electric wheelchair is experiencing issues where the LEDs are flashing and the chair won't move despite fully charged batteries, there could be several potential reasons for the problem. Here are some troubleshooting steps you can take:
  1. Check for Error Codes:
    • Electric wheelchairs often have a diagnostic system that uses flashing LEDs to indicate specific error codes. Refer to the user manual for your wheelchair to interpret these codes. They can provide valuable information about the nature of the issue.
  2. Inspect Connections:
    • Ensure that all the electrical connections, including those between the controller, motors, and batteries, are secure and free from corrosion. Loose or damaged connections can disrupt the functioning of the wheelchair.
  3. Reset the Controller:
    • Some wheelchairs have a reset button on the controller. Try resetting the controller by turning off the power, waiting for a few seconds, and then turning it back on.
  4. Check Joystick Operation:
    • Verify that the joystick is functioning correctly. Sometimes, issues with the joystick or its wiring can affect the chair's performance.
  5. Test Batteries:
    • Even though you mentioned that the batteries are fully charged, it's worth checking their voltage and overall health. Faulty batteries can still show a full charge but may not provide sufficient power.
  6. Controller or Motor Issues:
    • If the problem persists, there could be an issue with the controller or the wheelchair's motors. In such cases, it's recommended to contact the manufacturer's customer support or a qualified technician for further diagnosis and assistance.
  7. Professional Inspection:
    • If the wheelchair is still under warranty, consider contacting the manufacturer's customer support for assistance. If not, seeking the help of a professional technician with experience in electric wheelchair repairs may be necessary.
Always prioritize safety when troubleshooting or attempting to fix issues with electric wheelchairs. If you are unsure or uncomfortable performing the troubleshooting steps yourself, it's best to seek professional assistance to ensure the wheelchair is properly diagnosed and repaired.
Jet7 power chair flashing red and yellow lights and not staying charged but a few hours at a time, had battery check, said they were ok. help
Hi June,
Any electromechanical device requires occasional troubleshooting. However, most problems that arise can usually be solved with a bit of thought and common sense. Many of these problems occur because the batteries are not fully charged or because the batteries are worn down and can no longer hold a charge. Below are a series of basic troubleshooting instructions for the Jet 7 Power Chair. This information is to be used as a supplement to the troubleshooting instructions provided in the owner's manual. If you have any questions about this information, contact your authorized Pride Provider. What if the systems on my Jet 7 seem to be "dead" (controller does not light up when the on/off key is pressed)? ! Make sure the batteries are wired properly-refer to the battery wiring diagram located on the power base. ! Make sure the connections on the battery terminals are tight and secure. ! Make sure the battery quick-disconnect harness connections are fully joined. ! Make sure the main circuit breaker has not tripped-push in the main circuit breaker reset button. ! Make sure the controller is completely connected to the power base. What if the range per charge of my Jet 7 diminishes over time? ! Determine if the batteries have ever been replaced. Batteries over a year old may be defective. ! Determine how frequently you charge the batteries in comparison to how often you use the power chair. If you use your power chair on a daily basis, you should charge the batteries every day for 8-14 hours. ! Determine when the batteries were last charged. Even if the power chair has not been in use, the batteries should be charged once a week for 12-14 hours. ! Determine how long you let the batteries charge. It takes 8-14 hours to fully charge a depleted set of batteries; continual undercharging reduces the overall life of the batteries. ! Observe the ammeter during battery charging to determine if the batteries are receiving a charge. If the ammeter does not go up when the battery charger is plugged into the charger power cord receptacle and an electrical outlet, the batteries are not getting charged. Check the charger fuse and ensure the electrical outlet is good. ! Determine if a wall switch controls the electrical outlet used for battery charging. If a wall switch does control the outlet and the switch is turned off inadvertently, the batteries will not fully charge. ! Is an extension cord being used to connect the battery charger to the electrical outlet? Pride prohibits the use of an extension cord when charging the batteries. The charger should be plugged directly into a properlywired standard electrical outlet as the length and condition of the extension cord can have an adverse affect on the battery charger. ! Determine how far you let the battery condition meter LEDs go down before charging the batteries. If you continually allow the battery condition meter LEDs to fall into the red area, the overall life of the batteries will be reduced. What if my Jet 7 is operating slower than it has in the past? ! Determine when the batteries were last charged. When the battery charge gets low, the batteries supply less power to the motors, which causes the motors to spin slower. ! Determine the temperature of the power chair at the time the problem occurred. The Jet 7 electrical system will protect itself from overheating when its internal temperature gets too high by reducing the amount of power sent to the motors. When this happens, the power chair will gradually slow to a stop. Allow the power chair to cool down and it will resume normal operation.
What if my Jet 7 begins pulling to one side? ! Determine if the joystick is being deflected straight or at a slight angle. Even a small amount of deflection right or left will cause the chair to veer over a long distance. ! Determine if both manual freewheel levers are in the drive position. If only one manual freewheel lever is in the drive position, the other motor will not operate and the Jet 7 will veer severely. ! Determine if both tires are inflated to the proper psi if the power chair is equipped with pneumatic tires. Pneumatic tires should be inflated to 35 psi (2.4 bar). If one tire is inflated more than the other, the power chair will pull to the side that is underinflated. ! Determine if the caster wheels are pivoting freely. If either caster wheel is not pivoting freely, the unit will veer to the side. What if the Jet 7 powers up, but will not move? ! Determine if both manual freewheel levers are in the freewheel position. If the power chair is in freewheel mode, then the electronics will function but the motors will not spin the wheels. ! Determine if the controller is flashing a fault code. The Jet 7 comes equipped with a VSI controller. The VSI controller will flash a code via the battery condition meter LEDs if a system fault is detected.
# OF LEDS CODE CAUSE POSSIBLE SOLUTION One red LED 1 Low battery voltage Charge batteries Two red LEDs 2 Left motor open Make sure left motor is plugged into controller. Three red LEDs 3 Left motor wiring fault Contact your authorized Pride Provider. Three red LEDs 4 Right motor open Make sure right motor is plugged into controller. One yellow LED Three red LEDs 5 Right motor wiring fault Contact your authorized Pride Provider. Two yellow LEDs Three red LEDs 6 Inhibit active Contact your authorized Pride Provider. Three yellow LEDs Three red LEDs 7 Joystick error Contact your authorized Pride Provider. Four yellow LEDs Three red LEDs 8 Controller error Contact your authorized Pride Provider. Four yellow LEDs One green LED Three red LEDs 9 Brake fault Make sure both motors are plugged into controller. Four yellow LEDs Two green LEDs Three red LEDs 10 High battery voltage Contact your authorized Pride Provider.
What if the speed LEDs on the VSI begin to flash? ! Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, an internal charger inhibit feature keeps the power chair from driving. This is indicated by the VSI speed LED(s) flashing. ! Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to activate. ! Determine if all controller connections are plugged into the power base properly. If the 3-pin charger inhibit connector is not plugged in properly, then the charger inhibit feature will activate. What if the speed LEDs on the VSI begin to scroll? ! Determine if the VSI has been placed in lock mode. The VSI is equipped with a lock mode feature that prevents unintended use of the power chair. If the VSI is in lock mode, deflect the joystick full forward until it beeps, and then deflect the joystick full rearward until it beeps. The joystick should go back to the drive function.
I charging my electric wheelchair a DL 5.2i. when is changing completed?
On this controller there is a 6 light LED display above the battery icon which is below the horn button. Turn on the power chair with the 1/0 button and the LED display will light up. The lights are red on the left, yellow in the middle and green to the right. If all 6 lights are lit the chair is fully charged. Hope this helps.
Why is my merits DL 5.2i stuck in low speed ?
You may have a thermal rollback issue. Try charging the chair overnight and leave the controller on while charging. This will give the control module/joystick time to reset themselves. Thermal rollback happens when a certain temperature in the motors is reached. The system shuts itself down to protect from damage.
Shoprider power chair won't move and 8 Battery LED Lights are flashing
Code 8: Controller problem. Also, check to see if your gearbox levers are engaged - if you can roll the chair by hand the gearbox is not engaging the motors.
2answers
I purchased a Pronto 41 wheelchair and a Winsunny battery charger. The charger didn't have a manual so I'm wondering what the best procedure is for recharging the batteries. Do I need to turn the...
Joe See my tips on charging batteries No you don't have to leave the chair on when charging. Charge overnite after using it during the day. Always have the charger off when plugging it into the chair and unplugging from the chair. The charger you have doesn't have an on/off switch so get a power strip with the on/off switch, plug that into the wall and plug your charger into the strip use the switch on the strip to turn the charger on and off this will save you having to plug and unplug the charger rom the wall. Always store or put the chair up fully charged. If you don't use the cair daily charge at least once a week. It takes 9-10 chargings to get the batteries operating at 100% so use the chair and charge overnight while you sleep Never leave the charger on the chair more than 12 hours Hope this helps you
2helpful
Merits DL 52 i electric wheel chair, all leds flash 3 times as a error code. Battery is fully charged, then turn on wheelchair. All led are on. then when the joy stick is pushed, all leds flash 3 times...
Merits DL 5.21 Electric Wheelchair. I need an owner's manual for it please?
Starla Oldham
It appears that there is no manual listed online, but I think that is because you are reading off the DL 5.21 from the controller and that is just the controller model which is made by an electronics company not Merits. The models start with 'P' and 'R'
Power Wheelchairs - Merits Health Products
meritshealth.com https://www.meritshealth.com > power-wheelchairs
Power Wheelchairs. Product Category. Show All. Folding/Portable. Front Wheel Drive. Mid Wheel Drive. Rear Wheel Drive. AVID Mid Wheel Drive.
Folding/Portable · ‎Accessories · ‎AVID Mid Wheel Drive
Merits Health Products: Merits Home
Merits Health Products https://meritsusa.com Feb 10, 2023 - Merits Health Products has multiple categories of power chairs: portable, standard, and heavy duty. Scooters. Merits Health Products has ...
Contact Us · ‎Our Products · ‎Resources
https://www.google.com/search?q=Merits+DL+5.21+manual
S246 manual here
https://www.yumpu.com/en/document/read/36678740/s246-owners-manual-merits-health-products
Batteries are normally 2 x 12 volt 20 amp hour (AH) for the outdoor scooter type. Indoor wheelchairs take one.
Led lights flash and Pride Go chair won't move.
Firstly disengage the drive levers and then "flick "them in fash.
Second pull out the large plug that is between them.
Check for damaged or bent or loose pins. press it home firmly .
I did this on my wifes chair and she zooms around.
All switched etc should be off during charge.
Lastly i fully discharged then recharged the battery to ensure no "battery charge memory".
To fully dicharge i shoved a small box between back wheels so to lift of ground and then a elastic band to hond controler on.
Top Electric Mobility Health & Beauty Experts
Rob Hill
Rob Hill
ZJ Limited
ZJ Limited
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
