Panasonic Kx-ta7731 Kxta7731 Kxt 7731 7731 Kxt-a Logo
M
MARIA JORDAN Posted on Aug 22, 2014
RETRIEVE VOICEMAIL FROM PANASONIC KXT-7731 - Panasonic Kx-ta7731 Kxta7731 Kxt 7731 7731 Kxt-a
marcusmcd
Level 1:
Problem Solver:
  • Contributor 32 Answers
  • Posted on Aug 22, 2014
marcusmcd
Contributor
Level 1:
Problem Solver:
Answers
32
Questions
0
Helped
6292
Points
92
In the settings menu there will probably be a menu for voicemail somewhere. There should be a number for connecting to the voicemail delivery service. If you are with O2 it is 901 in UK.
Does a panasonic kx t 7731 have built in voicemail and if so how do i program it
You need to get a voicemail system. The 7731 is just a phone, but it can be used to access Panasonic VM or Built In Voicemail in a TA-824 system. The external product is a model TVA-50 and it comes with documentation on how to interface it to your phone system. If you have an old KXT-308 or 616, or any other older Panasonic system prior to a TD-816/1232, you're going to have a problem.
Carl
Carl
Hello there. Please tell me, does the Panasonic KX-T77330 have an inbuilt voicemail system?
A 7730 is a Panasonic phone that can connect to one of 18 or so different systems. Voice mail can be in the system or external to the system. The phone doesn't have VM on it. External VM has model numbers like TVA/TVS and connect to TA/TD/TDA/TAW and 123211 models. Internal models have names like SM or ESM and install in TA/TDA/TAW systems. No voice mail fit in the old KXT-308/616 systems as there's no integration.
Carl
Does the Panasonic KXT 7731 2-line have a music/message on hold port on it's KSU?
All Panasonic systems that the 7731 would plug into has an MOH port. You provide 8 or 600 ohm sound levels and do some programming to make it work.
Carl
How do i program the panasonic kxt-7731 so when a call is coming in i can just lift the handset to answer instead of pushing the co line
You have to do 2 things: Make it ring and turn on Line Preference-Incoming Ringing line. The first is done from SYSTEM programming in programs 408/409/410 for DAY/NIGHT/LUNCH. The second is defaulted to Ringing so if the phone rings, it's supposed to work. If you've changed it, then from your idle phone you press PROGRAM and dial 22 STORE. (21 is no preference and 23 plus a number is a specific line).
Carl
2helpful
Panasonic Kxt 7731
What happens when you dial "9" into the intercom dial tone? Is that the line you wnat to auto select?
A lot depends on the system your phone is connected with. In a TA series on an idle phone, press PROGRAM 11 for no preference (what you have) 12 for Idle line (what you get when you dial 9) or 13 and a number from 1 to however many lines you have to select a specific line.
Those commands are followed by the STORE button and PROGRAM to end the programming.
Carl
I need to change the time on my clock - Panasonic KX-T7730
There are a few types of phone sytems that work with the kxt 7731. these instructions should handle most of them.
Changing the time on a Panasonic KX-TA624 system must be done from extension # 101 using a display phone. All others can use any display set.
1.- Press the "PROGRAM" button on the face of the phone
2.- Enter programming mode by pressing "STAR" - "POUND" - "1234" (default password = 1234)
3.- Enter program # 000
4.- Press "SPEAKER" button
5.- Press "FORWARD/DND" button to change to the hour selection
6.- Press "TRANSFER" button and enter the hour
7.- Press "FORWARD/DND" button to change to the minutes parameter
8.- Press "TRANSFER" button and enter the minutes 9.- Press "FORWARD/DND" button to change to the AM/PM parameter
10 Press "MUTE" button to select AM or PM
11.- Press "STORE" button (listen for 1 tone if procedure was executed correctly / 3 tones if procedure failed)
12.- Press "HOLD" button
13.- Press the "PROGRAM" button on the face of the phone
2helpful
Simplify the changing of the timeon the Panasonic phone KX-T7731
Changing the time on a Panasonic KX-TA624 system must be done from extension # 101 using a display phone. All others can use any display set. 1.- Press the "PROGRAM" button on the face of the phone
2.- Enter programming2.gif mode by pressing "STAR" - "POUND" - "1234" (default password = 1234)
3.- Enter program # 000 4.- Press "SPEAKER" button 5.- Press "FORWARD/DND" button to change to the hour selection 6.- Press "TRANSFER" button and enter the hour 7.- Press "FORWARD/DND" button to change to the minutes parameter 8.- Press "TRANSFER" button and enter the minutes 9.- Press "FORWARD/DND" button to change to the AM/PM parameter 10 Press "MUTE" button to select AM or PM 11.- Press "STORE" button (listen for 1 tone if procedure was executed correctly / 3 tones if procedure failed) 12.- Press "HOLD" button 13.- Press the "PROGRAM" button on the face of the phone
6helpful
2answers
Changing time
What to dial to access panasonic esa phone 616
Panasonic never issued a manual for R3. It was done with addendums that got you from R1 to R2 to R3. I think these are the right codes, but you may have to test them.
External page should be 33.
All Page (internal, I think) is 34. It's also the page transfer code.
Groups 1-4 are 35-38. (All phones are in group 1 by default)
43 is the "meet-me" code. It can retrieve any page or transfer to page.
Here's a link to a manual(s) if you need it.
http://public.carl.airpost.net/KXT%20Analog/KX-T61610_IM_PM
http://public.carl.airpost.net/KXT%20Analog/Panasonic%20KX-T616%20Station%20User%20Guide.pdf
Carl
Top Panasonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
