Televison & Video Logo
A
Anonymous Posted on Aug 22, 2014
Hi I have a PACE PVR Decoder which skips channels when p+ / p- is pressed
timmysm
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Aug 22, 2014
timmysm
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
Helped
8503
Points
42
Hi, This may be due to one or two things. The remote and the box should have P+ and P- buttons. If the box operates ok but the remote doesn't the remote buttons are causing what is called switch bounce and needs replacing but if the box and remote jumps channels they are not the cause but programming and memory retention of the PVR.
Make sure the pvr is not recording anything first as this may inhibit some channels from showing. go to the update page and make sure that the box is fully updated. Another reason could be the aerial not giving strong enough signals for some of the multiplexed stations. To check this select the channel number rather than using P + or P-.
If the channel does not show it could be signal related or moved to another number and not updated. Tim
1 Related Answer
Anonymous
  • 5 Answers
  • Posted on May 04, 2012
SOURCE: sd pvr remote
it sounds like the remote needs to be re-programmed to work with the device. the 2 blinking dots illistrates that it is looking for a device to operate.
1helpful
Dstv remote not working on any blue dials? Two tv's in separate rooms, one pvr decoder. Only the red dial works on both tv's & both remotes are working & both tvs responding properly.
Is this a newly installed system? If both tv's are responding to the same remote setting (red in case), it means both tv's are set to the same channel. The tv that is connected to the decoder directly (via AV cables, I presume) is supposed to respond to if the remote is set to red. In order for the second tv to respond when the remote is set to blue, you need to tune the second tv until you find the picture of tv2 (the decoder transmits both tv1 and tv2 on the RF/coaxial output and it seems that your remote tv is tuned to tv1 instead of tv2).
Sd pvr remote
1helpful
2answers
Connecting pvr dstv decoder 3001
My pvr decoder model 3001 remote control doesn't work I checked battrey it works but no answer for decoder what shall I do
How to program my urc 4220 remote
Hello
Direct code setup for easy device programming
The One For All 4 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, aMotorola cable
box, and an RCAVCR.To control devices other than the default brands,performthe
following steps; otherwise skip this section:
[1] Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insertmedia (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
[2] On the remote control,press a device key once (i.e., VCR/PVR,
DVD,CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press VCR/PVR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume,andVCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD once.After programming
a DVD Combo device, you will be able to control channel selection,
volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
[3] Press and hold SET until the LED (red light) blinks twice,
then release SET.
[4] Use the Manufacturer's Codes (starting on page 36) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
[5] Aimthe remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
Repeat steps 1 through 5 for each device you want to control.
[^] For future reference,write down each working device
code
OK.
I have a Samsung LE26R8 tv which is HD ready, It has built in freeview will i get HD channles or will i have to get a HD tuner
Hi, Your TV is set for HD but you will need a set top box. (PVR) You will need a digital decoder to recieve HD or digital channels. Talk to your cable or dish companies for more info. Good luck.
I am having problems programing my Maxent MX50X3 TV to our Direct TV system.
Hi, Your Direct TV system runs on channel 3 or 4 on the Maxent HDTV and the decoder box(PVR) works all the channels. So you might not be able to program your HDTV. Good luck.
1helpful
Our Shaw cable box,Pace PVR,continously BLANKS out for no reason,When it does the guide on the tv says to be anounced for a minute or more! Changing the channel or hitting the channel guide up usually sets...
I have had the same problem and I spoke to a tech at one of the tv repair shops in Edmonton. He says it is a long standing generic problem that Shaw is having with the HDMI connection between the pvr and tv's, I have a pvr replaced twice and the problem remains. The last Shaw tech says to use component cables and it will solve the problem which I believe is an admission that the problem identified by the tv tech is true. Doesn't help with 4 hdmi.and two component inputs
Split screen
Yes I get the same problem with my Sony XBR and its Pace PVR.
The problem seems related to using HDMI interconnects; viewing the PVR through component leads allows the TV to switch modes easily, otherwise I have to turn the tv off and then back on again.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
