MSI U230 Light087 Netbook Logo
A
Anonymous Posted on Aug 22, 2014
How do I switch from WIFI to ETHERNET which function key (symbol) MSI U230 ?
I am connected by Ethernet cable but using wireless WIFI I cant switch the two I WANT A BETTER CONNECTION
Floyd J Stalinski III
Level 2:
Habit-Forming:
  • MSI Expert 89 Answers
  • Posted on Jan 14, 2015
MSI Expert
Level 2:
Habit-Forming:
Answers
89
Questions
0
Helped
44689
Points
499
First try keystroke fn+f10
If that doesn't work, try the following:
Follow this sequence to reach DeviceHow do I switch from WIFI to ETHERNET which functi - icon1.png Manager.
1. Click on Start Menu / Right-click on Computer / Click on Manage.
2. Click on Device on the left column, and then double click on Network adaptersicon1.png.
3. You should see 2 adapters, double-click on your wireless adapter to enter property.
4. Go to Advanced tab, select Radio Power and make sure it's set tHow do I switch from WIFI to ETHERNET which functi - icon1.png.
5 Related Answers
mail2pvs
Pavan Ponangi
  • 390 Answers
  • Posted on Jun 23, 2009
SOURCE: My wireless connection works on all the other
hi
check for the necessary ip addressing formats as well as if any DNS server addresses are required to connect to the network
if all is fine then try
right click on the network icon click on repair
try surfing if still not able to surf try the steps a couple of times
cheers
Azrael SRL
  • 11800 Answers
  • Posted on Nov 04, 2009
SOURCE: I have a msi u100 and the keyboard keys do not
 Wrong keyboard mapping.
Start / Control Panel / Regional and Languages Options / Languages / Details / in there select the keyboard arrangement you want - most likely the english EN one.
Anonymous
  • 35 Answers
  • Posted on Apr 02, 2010
SOURCE: cant get my wireless connection to work not sure
To enable/disable WLAN, please press "Fn+F11" to execute the device: (then follow below steps accordingly)
Note: there are four stages in all, assumingly both bluetooth and wifi are installed.
First stage : press Fn+F11 = Enable WLAN only
Second stage : press Fn+F11 = Bluetooth On + WLAN Off
Third stage press : Fn+F11 = Bluetooth On + WLAN On
Fourth stage press : Fn+F11 = Bluetooth Off + WLAN Off
After enabling the WLAN, search the Access Point and connect with it. Now, you may use the WLAN.
If this does not work, check if the driver is installed in your computer by going to the device manager. check under network adapters. If the driver is installed, uninstall the current driver and restart the computer.
If the issue still persists, you may download the driver update at the msi website: http://www.msi.com/index.php?func=nbdriver&maincat_no=135&prod_no=1474. Just make sure the driver you're downloading is compatible with yoru operating system
Anonymous
  • Posted on Feb 11, 2011
SOURCE: Where is the wireless key
hold down the "fn" key and press "f11" this will turn on your wireless key
Anonymous
  • 6771 Answers
  • Posted on Jun 04, 2012
SOURCE: Keeps saying boot failure along with Ethernet controller v1.06 and media failure, check cable
What you are describing is a hard drive issue, remove hardware and reseat it back in place sometimes this will restart the hard drive. If this fails have it tested.
I have a lg bp630 3D dvd player that's new, only theres a problem, when i try find my wireless network to connect it wont find it, infact it does not find anything.. Cant try connecting via Ethernet cable...
Use a wireless extender. Then from the back of the extender use Ethernet to plug to your player. Better still, plug it into a switch and then you can use the switch to connect multiple devices using Ethernet which is much faster than the built in wifi.
tip
I think there are 6 ways (at least?) to connect this printer: (1) Direct to Mac...
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable(3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch(4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless)(5) WiFi to router, with Mac/PC via Ethernet to router/switch(6) WiFi to router, with Mac/PC also via WiFi.
As (1) should be simplest, tried this first. First document would print instantly and completely, next doc would hang in queue with unexpected msg, "Printer is offline." Only way to print 2nd doc was to power cycle (off-on) the printer. This problem occurred whether 2nd doc was sent to printer before or after 1st doc had printed. Tried 2nd USB cable, tried new driver, tried reinstalling printer; same problem. Spoke to both Samsung and Apple support, including both on a conference call; never got this to work and never clarified if problem was in printer hardware/software, driver, or something else. Both companies now showing this issue as unresolved.
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Procedure required connecting first via Ethernet, obtaining Configuration Report by holding down orange button for 5 seconds, then using browser to connect to the printer's IP address. Also required different driver for wireless config (as opposed to USB).
Bottom line: What seemed simple - USB direct connect - proved unworkable, but wired and wireless network config works fine.
2answers
How to find wpa key
You can find the wpa key by loging into the router interface, and checking the wifi settings. You will have to be connected with an Ethernet cable or use a computer that is already connected to your wifi.
Start by getting the ip address of the router:
1.Press the "windows"+"R" keys (this will open the "Run" dialog box)
2.Enter "CMD" in the Run window, and press ok
3.In the Command Prompt window enter the following command "ipconfig" and press enter
4. locate the Ethernet adapter or local area connection if using an Ethernet cable. If you are using a wifi connection, you want to locate the wireless Ethernet connection.
5.Under one of those headings you want to locate the "Default Gateway" address. It will most likely be similar to one of the following: 192.168.1.1 or 10.0.0.1
6.Open a web browser and enter the address you found under the default gateway.
7.You will get a login page for your router. Usually the login formation is as follows:
admin/admin
admin/password
admin/leave the password blank
9.Once you have logged in you want to locate the wifi/wireless menu on the page.
10.Here you will find the wifi password
Web is not working in hcl notebook
your notebook has a switch to turn on/off the wifi. Try using hardwire ethernet cable to connect to the web. locate the slide su=iwtch or function on the keyboard marked as WiFi symbol
I can no longer get a wireless online connection. The wireless signal strength says "excellent", but the connection is "Local Only". It does work however with the Ethernet cable which...
ok so wifi fails we all know why the 100reasons,
why not use a 2nd PC to see if wifi fails there too
easy no/, ends all guessing what's up.
your post is not clear at all does the internet work wired.
yes/no
using a real browser to amazong or ebay etc.
that matters now what windows thinks, in CP
wifi is complex, (when failed)
so say what ethernet does? (real online)
and learn that in the taskbar, you switch off wifi first to run on Ethernet. it will show icon for ethernet . and good. and browsing works. the web.
if only 1 PC fails on wifi we fix the PC fails
of 2 PC fail we fix the router. see?
1helpful
3answers
No wifi
Hi its very small switch with the WiFi symbol on it check at the front of your laptop and some laptops have it at the side you can find it easily check carefully
thank you
if this information is useful kindly vote for me
hbristol173
My laptop can wifi acer AOD150
Yes you have a Ethernet connection and a wireless 802.11 adapter so you can use wifi - Most laptops have a wireless switch - some a physical switch other use a combination of the FN key + one of the F key to toggle on/off - make sure this is on.
1helpful
I have a siemens gigaset se587 wireless router and a xbox360 network adapter it does not connect up to my network where am i going wrong I have connected it up using the ethernet cable and it works fine...
sorry to bother but i cant get xbox live to work with the ethernet cable, where did u plug the ethernet cable into? ive tried different places and none seem to be working
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
