I noticed that the choke is opening and closing and that the spring attached seems to be stretched
If you have had fuel sitting in it for a while, it has probably blocked the jets in the carb. You might need a carb rebuild kit if it has perished any of the carb parts such as the float or the needle seal.
We sell parts for your generator if you need any.
Generator Guru
Replace spring apparently it lost its tension for it to stay open you may also have a dirty carburetor if it does not run smoothly with the choke wide open have it serviced or clean it yourself if your mechanically inclined it should be a piece of cake.
