Would like to be able to answer calls only during business hours
SOURCE: answering machine
Your phone can be programmed to transfer a call to different places and have different rules for day-ring mode and night-ring mode.
Sounds like what you want to do is change your phone to transfer to another extension instead of your voice mail box. This would in effect eliminate your voice mail box because a call would never automatically be sent to it unless you use (and program correctly) night mode.
Your phone model type does not help resolve this. You can have this phone on different Panasonic phone systems. You will need to determine which phone system you have and locate "programming" manual for the specific system (not a user guide)
There should be a section or option called "no-answer forward", "forward timer", "forward extension" etc...
SOURCE: Panasonic KX-T7730 does this phone have answer machine?
try using the call forwarding feature, you can forward it to your cellphone.
SOURCE: Digital panasonic kx-t7633
The 7633 has a FWD/DND button. Is it blinking, lit solid or dark? It's designed to be pressed 3 times for FWD DND or OFF....It's programmed as follows, assuming that 500 is your voice mail access code:
From the intercom dial *7101. That sets DND. Dial 710x 500 # to set call forwarding where x-2 for all calls 3 for BUSY for for NO ANS 5 for BSY/NA. 7&8 are FOLOW ME commands and they have a different set of instructions ie Dial *7107 plus your extension to have calls come to the phone you're at and *7108 plus your extension to cancel it. I have never seen it used. *7100 cancels all forward and DND arrangements from your phone..
This is just hte command set for ALL CALLS. You can also set up forwarding for Outside Calls and Inside calls seperately and you can program buttons to do the forwarding.
Your Panasonic dealer has 2 manuals that you would find interesting, one is the TDA Operating Manual and the PTPM Manual. The operating manual has a complete set of programming instructions for the manager and users of TDA systems, the PTPM has a complete set of programming features that can be performed from a Panasonic 76XX display phone.
THe pdf's aren't huge and they can be sent to your email address if you provide one under the Ask Me button.
Carl
SOURCE: Need instructions for setting up
For the manual, go here =>
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/DECT-6-0-Phones/model.KX-TG9343T
For the accessories, go to the same link above.
Click on Parts and Accessories Tab.
Then scroll to the bottom and Click on Parts Link labeled "See Parts Available For This Model"
If the link does not work, start here =>
http://www2.panasonic.com/consumer-electronics/support/Operating-Instructions
SOURCE: PBX: KX-TA624 PHONE:KX-7730b. need to forward call to outside lin
Sorry that We were disconnected from our chat session.
Here is the manual guide explained with steps for forwardign ur call:
http://service.us.panasonic.com/OPERMANPDF/KXT7720.PDF
Check out the "Page 6" in this manual
