SOURCE: Set Tax rate on a Casio HR-100TM
Press the CA button twice. Then push and hold down the %/set key until the 0 dissappearsd and reappears. Then type in your tax rate and the percent key (eg: 8.25%) and then press the TAX+ key. It should save the new tax rate.
SOURCE: How do I change ink cartridge on HR-100TM Casio
the G24 ribbon is having 2 round shape casing. u need to take it out from the knob. but be careful when u install a new ribbon, make sure u slot in the ribbon in correct way
SOURCE: how to reset tax % on casio HR-100tm
the 0 disappeared and reappears. Then type in your tax rate and the
percent key (Eg: 8.25%) and then press the TAX+ key. It should save the
new tax rate.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: THE CASIO HR-100TM HAS AN E ON THE SCREEN AND
First, check the batteries, and ensure there is not a paper jam in the printer.
If both are fine, then while the calculator is in the "Print" mode, press the [CA] (or [AC]) button 20 times consecutively to clear out memory buffers. Try some numerical calculations, and if the problem persists, repeat pressing the [CA] button 20 times.
If the problem still persists, then the calculator may require service.
http://www.casio.com/support/techsupport/AABF4C3A-D2EF-4BF5-B349-48459AF35FF0
