My TomTom ONE is stuck, even after reseting multiple times. I can't get the map screen to come back up. My Unit is less than a yr. old. Please help!!!
I found this.
Question: Device shows a flashing cross when turned on.
Answer:
If your device only shows a cross after you turn it on, the TomTom application is not installed or cannot be found.
To solve this, follow the steps below.
Manually remove the TomTom application:
Reset your device.
Connect your device to your computer.
Turn on your device by pressing the power button for 5 seconds.
Do one of the following:
Windows: Click Start > My Computer and then double-click the Removable Disk for your TomTom device.
Macintosh: Double-click the desktop icon for your TomTom device.
Delete all files except the following:
Do not delete any of the folders!
Do not delete the files antitheftw.bmp, lowbatteryw.bmp and splashw.bmp (if present)!
Reinstall the TomTom application:
Start TomTom HOME
Select an option:
I previously updated my device on this computer
I never updated my device on this computer
Click Done and then click Device > Disconnect Device.
Your device should now start up again. If it hasn't started up after 10 seconds, press the On/off button.
The above information worked for me perfect............Thanks, Kim
If your tomtom is working on tomtom home so you can add things
then all you have to do is restore it and update it again!
easy! works for me
my tomtom one seem not to be charging
hooked tomtom to my laptop n downloaded updates now it only displays picture of tomtom and a flashing x tried to reset wont work
Same problem after downloading update have only flashing cross. This is the second time it has been back for repair because it happened the first time I connected it. Tomtom sent instructions to reset and update from computer now says I need to delete 6.1mb to do this, but I only have a folder showing on the device of 'statdata 1 byte disallowstrip.dat' and they have told me not to delete any folders only loose files.
Connected tomtom one 3rd edition to my computer and downloaded updates now it only displays picture of tomtom and a flashing X. Tried to reset but still flashing X.
Not only do I continue to get a flashing red "X" when I connect my Tom Tom to my PC it does not recognize a Tom Tom device connected.
i have same problem, have flashing x and cannot connect to pc to update .
A flashing red "x" appears on the tomtom screen. I can't do anything with it.
