Hi Friend, this is Z. I appreciate your inquiry!
I interpret that you are having trouble with your Frigidaire dryer (FASE7073NW) not starting. Let's try resetting your dryer by flipping the household circuit breaker to the off position. It is necessary to wait roughly ten minutes and then turn on your dryer. Confirm that the door is securely closed and select a cycle. If resetting the power does not correct the issue, I have identified that it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would personally contact a professional to accurately diagnose your dryer to determine the root cause to reduce the risk of unnecessary parts. Best regards!
SOURCE: how do you replace the
The fuses or breaker is located in your homes fusebox. An electric dryer requires 240 volts and 2-30amp fuses, or 1-30amp breaker. Locate your fusebox and determine if you have fuses or breakers. If fuses, then I recommend changing both 30 amp fuses to eliminate any possibility of being wrong. If it uses a breaker,(If not labled, look for the number 30 on a breaker). Flip the breaker to the OFF position, then back to the ON position. Repeat this action if there are more than 1-30 amp breakers and your dryer still doesn't heat.
SOURCE: Brand new Dryer starts then stops after 15 seconds
Stop what you are doing. It is under warranty. This will be more costs and it is not necessary. It is a mfr problem.
SOURCE: frigi
There is something in the control panel that is sending a trouble signal. Your manual should tell you about this. Have you had this very long? It may be under warranty.
SOURCE: iDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
Great. This is the same error my electric dryer is showing now...
I believe that code means auto dry. Lets make sure the lint and dust is clear from the machine. Check all of your wiring out well since is generally a cause. You may ave to replace the thermistor. Have you gotten any other code along with this.
Testimonial: "Thank you Bill Dickerson, I have found my manual now for error codes and how to read them and am now getting E56 on digital display read out. But not showing that error code on the manual???"
Hold the "Control Lock" button, located in the bottom corner of the controls, for five seconds.
