I've adjusted both tension dials to all possible settings and it still doesn't work properly. Brother xl2600i
SOURCE: I get loops on top and/or bottom of fabric during
Top tension back to 4 and leave the bobbin tension as is.
Make sure you have a new needle for the type of fabric being sewn installed with the flat side to the back of the machine. A bent needle can sometimes go unnoticed.
Always thread the machine with the presser foot up and this will give proper tension to the stitch.
Check the manual to be sure you are threading correctly (always with the presser foot up) and that the bobbin thread is feeding in the correct direction from the bobbin spool and through the guides.
Take hold of the thread at the needle as you lower and raise the needle to pull up the bobbin thread. Take both thread ends under the presser foot and to the back of the machine.
SOURCE: Tension problem Bottom thread is loopy and sloppy
SALUDOS, MI MAQUINA HACE ESACTAMENTE LO MISMO UN DIA DERREPENTE DEJO DE BORDAR Y TIRA TODO EL HILO, LO HACE BOLAS POR LA PARTE DE ABAJO, Y DESCUBRI QUE SE ROMPIO UNA LAMINITA QUE LLEVA FRENTE A LA LANZADERA DONDE SE COLOCA LA BOBINA.
TAL LAMINITA SE LLAMA RESORTE PERO NO TIENE NUMERO NO LA HE PODIDO ENCONTRAR, DICHO RESORTE VA INSTALADO AL LADO DERECHO EN EL MISMO LUGAR DONDE ESTA INSTALADO EL LASER. AGRADECERIA ME DIERAN EL NUMERO PARA PODERLA COMPRAR. MIL GRACIAS.
SOURCE: Thread tension for Brother XL 2230.
If you have pattern dials set correctly then I might guess that one or more sets may have been missed when the thread was being set up in the machine. most of these models show either arrows or numbers for each or way the thread needs to be routed.
SOURCE: My brother sewing machine is sewing with the
It is in your top threading, something is not right in the path. Always remember, it is the opposite of what you think. So, underside will mean that the top thread is the problem
SOURCE: tension problem
.There is a little screw attached to the bobbin carrusel. You can try
to turn it just a little bit. The reason is that this carrusel gets
loose after a while.
Clean and oil your machine at least monthly.
Hope something helps!
