Can not receive faxes. Unit is connected directly to phone line. Why am I having this problem?
i solved question.Contact now
Lexmark Printer Support
SOURCE: cannot send or receive fax
you may wish to try this link, and see if you find what you are seeking
www.lexmark.com
SOURCE: can't receive or send fax on my lexmark X4270
I'm trying te reset my fax. I've. put in date and country and know the screen is displaying format and pushing options and select and the screen not changing
SOURCE: does not recognize phone connection
Hi. Here are some things you need to check: 1. Check the physical connection. Make sure the phone cable you're using is still in good condition. No obvious defects. 2. There are two phone ports behind the printer- Ext and Line. The phone jack from the wall should be plugged in to the Line port of the printer and not in the Ext. port. 3. Make sure to enter your Fax name and the correct Fax number in the printer. These are the basics on how to setup the printer for faxing. Hope these helps.
To receive faxes manually, follow the steps below.
