I have assigned a speed dial number to some of my contacts, I press the speed dial number and nothing happens, I guess I don't know how to use the speed dial feature can you assist me?
Yup, you can set a maximum of 8-speed dial entries.
1. From the main menu, select Settings > Phone settings > Keypad > Numeric keys.
2. Highlight the key with which you wish to assign the speed-dialing number (from 2 to 9), pressEdit > Contacts.
3. Scroll to choose a contact you want to assign from Contacts and press OK.
ok, here's how to assign speed dials on a c3560....
press top left button for menu,
highlight contacts, then press ok,
select favourites tab,
highlight any not assigned numbers,
press top left button to assign,
contacts pops up,
press top left button to bring up contacts list,
highlight contact you want to assign,
press top left button to select & you're done !
Unsolicited advice from a "senior":
Eventually, you may wish to consider a Jitterbug phone for your mother. They are designed for seniors and have low cost monthly plans, much like Tracfone. See the Jitterbug cell phone information here: https://www.greatcall.com/phones
Scroll down that page and click on the Compare Plans link.
To assign a number to a speed dialing key, select Menu > Address Book > Speed dial list, and scroll to the speed-dialing number that you want. Select Assign or, if a number has already been assigned to the key, select Options > Change. Select Find and the contact you want to assign. If the Speed dialing function is off, the phone asks whether you want to activate it
FOR MAKING CALL
Assign a phone number to one of the speed dialing keys, 2 to 9. Call the number in either of the following ways: • Press a speed dialing key, then the call key. • If Speed dialing is set to On, press and hold a speed-dialing key until the cal
Set speed dial numbers 1. In Idle mode, press <Menu> → Phonebook → Speed dial. 2. Scroll to a number you want to set (2-9) and press the Centre key. 3. Select a contact to assign to the number. The contact is saved to the speed dial number.
You can now call this contact from Idle mode by pressing and holding the assigned speed dial number.
More info about your phone: http://downloadcenter.samsung.com/content/UM/200802/20080205151101875_SGH-J700_UG_Open_Eng_Rev.1.1_080125.pdf
How do I set speed dial for one of my contacts?
First, find the contact in your Contact List, highlight it, and press OK. Then select Options -> Speed Dialing and press OK.
Choose one of the numbers from the list and select Assign
to assign it to your contact. You can now use 1-Touch Dialing for that
phone number. Just press and hold that assigned one or two digit number
instead of dialing the contact's entire phone number.
I have done it. I have found a way to chance the speed dial settings on my Samsung D900i.
The following instructions work for my phone but I cannot guarantee they will work for everyone else. YOU WILL NEED A PEN AND PAPER.
Press Menu > select Phonebook > Speed dial (4) >Select
You should see names assigned to the numbers.
Decide which speed dial number you want to change e.g. 2 Mum Mobile (remember the name)
Press Back > Contact list (1) Select
Type in/go down to that name e.g. Mum Mobile (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > choose Yes > Back > Speed dial (4)
You should now see that Mum Mobile has been replaced with a big number 2. This means that speed dial number 2 is un-assigned.
Press Back > Contact list (1) > Select
Decide who you want to be assigned to speed dial 2 (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > Yes (HERE IS THE WEIRD THING)
Press Back > Create contact (2) > SIM (2) >Select
Type back in the name and number of person you have just deleted > Save > Back > Speed dial (4)
You should see that Speed dial 2 is now the person of your choice.
HOW COOL IS THAT!!!!!!!!!!
Press Back > Create Contact (2) > Select > SIM (2) > Select
Type in Mum Mobile and Number (THE FIRST NUMBER YOU WROTE DOWN) > Save.
That is it, repeat the instructions until you have all the speed dials of your choice.
Hope this helps the many frustrated D900i users out there.
