Changed out fame sensor and solenoid valve gas and spark ignite then goes out
SOURCE: new gas valve, new gas smell
CG, unfortunately you replaced the wrong part. The problem with your oven is the igniter. The igniter is wired in
series with a safety valve. The safety valve monitors the amount of
electrical current flowing through the igniter when you ask it to
"bake". When the igniter gets "weak" it won't allow current to flow
through it properly, this will keep the oven from heating. It will also cause your symptoms as well...
Here's the scenario; Say your safety valve is "looking" for 2.5 amps of electricity flowing through it before it'll open up and allow gas to the manifold. Your igniter is designed to allow 2.8-3.2 amps to flow in good operating condition, but your igniter has become "weak"... it's now allowing 2.48-2.51 amps. The safety valve is sensing this and opening and closing rapidly, allowing gas to flow through it (fluttering). BUT! the igniter is not hot enough to ignite the gas and/or there is not enough gas to ignite do to the fluttering effect of the valve. Sometimes it'll light sometimes it won't.
Your igniter is the cause and needs to be replaced.
Before
you begin the repair, you should have the new part on hand. The part
number is WB2X9154 and can be purchased at your local appliance parts
retailer for about $50.00. Here's one online for $65.00.
First, UNPLUG YOUR OVEN!
To
replace it... Remove the racks and lower panel (oven floor). This will
expose the burner manifold where the igniter is mounted. (It's the
round thing on the manifold near the back... it has 2 wires going into
it.) You'll need a 1/4" socket or nut driver to remove it.
(*TIP---> before removing the screws from the igniter, put a few drops of liquid dish
soap on the threads to lubricate them. If you do this, you will not
strip the threads of the screws and it will ease their removal.)
The
new igniter kit will have two ceramic wire nuts in it. Cut the two
wires off of the old igniter and strip them back about 3/8". Then
connect the wires of your new one to the wires in the oven using the
ceramic wire nuts provided. Then mount the new igniter and rebuild the
oven.
(*TIP---> The new igniter is very fragile! [that's why it came wrapped tightly in bubble wrap] Handle it gently!)
There ya go! Total job time? ~45 minutes.
SOURCE: Roper gas oven won't work
replace the thermal coupling on the pilot make sure it is in the flame of the pilot it looks like a copper wire or tube if its bad it wont open the gas valve after the pilot heats it up
SOURCE: Main Burner not lighting
This is caused by a faulty pilot safty valve. it will be the tee looking valve with the red dime sized button in the middle.
Hope this helps You
please rate me
SOURCE: spark module clicks and gas will not stay lit, flame comes on but goes out
hi
Clogged burners are a very common problem with gas ranges because foods spilled on the burners block the gas ports and prevent ignition. On some gas ranges you can remove the top ring of the burner to expose the ports. Here's how to clean a burner:
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
thank u.................
SOURCE: maytag gas oven wont restart after pre heat
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
12001655
The ignitor is not working right and is going bad....
have
the repair man replace the ignitor, or DIY....
Check out this tip
about your problem...
Oven not Working or Oven
not Heating
Oven
Problems Replacing the Igniter
heatman101
