Samsung color multifunct laser print clx-4195fw clx4195fw Logo
Samweli Boniface Posted on Aug 21, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My printer after charging the tonner it getting the msg not compatible
I tray to fix it but not working
Konica Minolta Error Codes and Solutions
Level 2:
  • Expert 210 Answers
  • Posted on Aug 21, 2014
Expert
Level 2:
Answers
210
Questions
0
Helped
153669
Points
393
Is the toner cartridge using a chip? if yes, you have the wrong chip inserted.
Having a msg put the tonner but the tonner is in..
I would recommend the following:
-Remove the cartridge from the printer
-Turn the printer off
-Wait 60 seconds
-Turn the printer back on
-Firmly re-install the cartridge
If the error message remains, there is likely to be a problem with the cartridge. In this case please contact your retailer.
Hi Sir. I got a problem of my Toshiba e studio 3510c printer, when I swich on the button, the screen shows there is a sentence said ;'disposal of the used tonner', should I replace the wasted...
It said exactly what? If it mentioned waste toner, emptying that tray (Toshiba has nice zero-waste-to-landfill toner recycling program) should have pretty much cleared things up; it appears that the sensor for that still sees lumps of toner..or something...coming up close to the paper path. Check it out carefully and replace the tray.
3helpful
3answers
I have a aficio mp c4000 printer/copier. it is telling me the waste toner bottle is full. where is the waste toner bottle?
The wast toner is placed next (next) to the first tray.
To reach there open the front door and you will see a screw (placed on top toward the main swith).
After unscrew you will be able to open a small door that hides the waste toner bottle.
Be careful because it is a little messy.
Good luke. If you need extra help reply to me
2answers
Where is this sensor(paper jam 0)?
For this you need to open back pannel of printer starting from page pick roller check the path of paper,check aroud when you'll open back pennel.
1helpful
Getting the msg "service call 22 man tray lift"...
This service indicator is referring to the main lift motor that is located on the rear of the machine, which comes in contact with the back of the tray and then engages to lift the paper up to the tray. I would suggest removing the paper tray and inspect the back of it, ensure that no parts appear broken and attempt to manually crank the arm that causes the paper to lift. If all is functioning on the tray side, then look towards the back of the machine through the front, make sure there is no lodged paper or debris. If no physical obstructions are present, and nothing appears to be broken and the paper tray aligns up properly, then you most likely have a failing lift motor.
Let me know.
-David.
6helpful
After refilling the tonner printer showing tonner
after refilling the tonner of xerox workcentre 3119 printer showing tonner empty message
I continualy get error msg to check printer cartridge, when new ones are installed same msg repeated.
I just replaced my black ink cartridge on the same printer and I'm encountering the same problem: a message that states "the black cartridge is not compatible with this printer". Well, that's not true. It is compatible. As a matter of fact, I got my printer (with new cartridge installed) to print a page once. But, now its giving me problems again and I can't get it to work. Help!
5helpful
''No Cartridge'' Error
check if the cartridge is a hp cartridge
if no use a hp cartridge
if issue stll occurs
open the cartridge door
remove the cartridge and the papers from the tray
close the cartridge door and turn off the printer
then turn on then printer
you will get a msg install black cartridge
open the cartridge door and put the cartridge inside and the papers in the tray and close the cartridge door
the printer will intiallize and you will get a ready msg on the display of the printer.
if you still get the msg have the printer serviced
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
