Question about LeapFrog Custom Learning Gaming System
My sons Didj won't work with an AC adapter. Can anyone tell me why??? It kills the batteries in about 2 days and I can't afford to put new batteries in it every 2 days! It will also just shut down randomly in the middle of a game. I am so frustrated! I bought it hoping my son could just play it, and instead we spend 95% of our time trying to fix it!
2 Suggested Answers
SOURCE:
SOURCE: My son's leapfrog didj will
This happened with the first Didj we bought. Struggled to open the battery case with the stupid recommended dime. [Use a screwdriver instead - better able to push down the lever inside the case.] The 1st Didj never turned on. Totally dead. Exchanged it. The second Didj was easier to open compartment to install batteries and turned on immediately. Reommend you take it back.
Posted on May 04, 2009
Medion MD 98200 My laptop will not turn on after my son removed the battery pack accidentally
Turn on the laptop without the battery, using only the AC adapter. If doesn't work remove the AC Adapter and battery. Hold down the power button for 30-45 seconds then plugged in the AC Adapter and put battery back in then [on]
Apr 11, 2013 | Computers & Internet
Hi. I have a HP Compaq 6820S, Intel Pentium T7250, 2 Gb RAM, 160 Gb HDD, i have a problem, Laptop won't charge battery. I let the laptop in sleep mode, around 7 days, when i come back, battery was 0%,...
try a new battery yet? (brand new fresh)
sleep mode. so you want it to run for 7 days in sleep.
ive no idea how long this laptop runs in sleep
and hibernate is longer.
no idea at all.
you do know that the speed features are programmable
right?
including what chips do and do not go to sleep'
like USB ports, WIFI, and all wake on , features. like Ethernet chip.
and more.
why not just turn it off, and let the battery last longer..
this mode sleep kills batteries faster. way faster.
leave it plugged in all the time to the wall pack.
so the battery never drains unless you need to use it, on battery.
Jul 18, 2017 | HP Compaq 6820s Notebook
New AC Adapter Will Not Charge Battery/Operate Computer
Most probably static electricity killed some circuitry inside your laptop.
Nov 12, 2009 | Acer Aspire 3610 Notebook
Didj will turn on but Warning screen is just frozen.
I had the same problem. What you need to do is open the Leapfrog connect and then plug your DIDJ into the computer. You also need to plug it in with the AC adapter as this takes time and the first time I tried the batteries died. So plug it in or put new batteries in it. Now just leave it sit plugged into your computer with the Leapfrog connect program open. It took mine almost 2 hours just sitting on the white Warning screen then if finally connected and updated the software and is now working fine. Hope this helps.
Jan 18, 2009 | LeapFrog Custom Learning Didj Racing -...
Can not get a game to play
I just got the Sonic game to play again. Unfortunately, I had to reset the Didj--i.e., erase all the contents, including "Jet Pack Heroes" and my son's profile. Basically, I had to reset it to factory settings.
So all the stuff we worked on is lost, but at least he can play Sonic.
I got the instructions here:
http://community.leapfrog.com/blog-entry/Bad-Christmas-Presents/Didj-Needs-Tune/580000606
And here are the instructions:
"Launch LeapFrog Connect
  1. Press the "Ctrl + Shift + R" keys on the keyboard
  2. A window will open that will say "connect the device you would like to reset"
  3. Connect the Didj and turn it on
  4. This will reset the Didj to the factory settings"
It didn't work exactly like this, but that's the command you want to use to reset it when connected to the computer via USB. You'll know when it's resetting--it takes a good 5-10 minutes and very clearly tells you that you're resetting.
Hope this helps!
Jan 16, 2009 | LeapFrog Custom Learning Case
My son's leapfrog didj will not turn on at all. I've tried putting brand new batteries in it, and I get nothing.
Jan 10, 2009 | LeapFrog Custom Learning Case
New Didj keeps shutting down
We were having the same problem; my son (an we) were getting very frustrated! I finally tried to reboot the game and it seems to have worked. Take a paperclip and bend it; place the point in the small circular opening in the back of the game (there is two arrows next to the opening). We just did this and my son played past the point where it would shut down. The manual said that doing this would erase all of the memory...this didn't seem to happen.
Hope this helps!
Dec 26, 2008 | LeapFrog Custom Learning Gaming System
Toshiba satelite A100 rejects AC... often.
Just to humor me, are you using any peripherals with your laptop when this happens, such as a wireless mouse, USB connections such as digital cameras? Try to take these away when recharging.
There seems to be 2 issues here.
1) Recharing batteries: To prepare the batteries for long-term use (I do not know how long you've had the batteries...try draining the batteries (both of them), and then recharging it to full 2x before using them without the AC Adapter. This should clear the problem.
2) AC Adapter only works every other day: When you swapped the power pack, was it with a new AC adapter, or another used one? Also, have you tried using a different outlet than the one you normally use? Let me know how this turns out.
Nov 17, 2008 | Toshiba Satellite A100-S8111TD Notebook
MY Laptop battery , Adapter or Motherboard
Did you buy an adapter that matches the same voltage and amperage values as your original?
Jan 11, 2008 | Acer Aspire 3100-1405 Notebook
LeapFrog Custom Learning Gaming System Logo
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
pramey3
Level 1 Expert
Keith Koene
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
