How do i change the laser unit of a brother printer
Can you show me how to changer the laser unit of the brother printer
  • 210 Answers
The change method is not the same for all the models. Can you specify the model name?
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Posted on Aug 21, 2014
SOURCE:
  • 13433 Answers
SOURCE: where can I get brother hl-2030 LASER PRINTER DRIVER
Hey,
The brother drivers and software require for the machine is available at
http://www.brother.com/E-ftp/info/index.html
Let me know if you need anything else.
Thanks,
Ekse
Posted on Mar 05, 2009
SOURCE: Brother Laser Printer, paper gets stuck and printing wipes off.
Opened up the back and found there is a plastic cog wheel on the end of an orange drum, which must be the Fuser Unit, which was damaged. So the paper was getting as far as the drum but the rollers to pull it through the Fuser Unit were not going round. A new Fuser Unit seems to be about £99 plus VAT and I don't supose a new printer is much more than that. So if anyone has a spare Fuser Unit for a Brother HL 5140 which is still in good working order I would be happy to consider buying it. Alternatively I have 2 x spare drums DR3000 and 1 x toner TN3060 for sale !!
Posted on Oct 26, 2009
cnavarro
  • 2460 Answers
SOURCE: We bought a Brother laser printer in 2009. Cannot
Both are available on the brother website. You have to click on downloads, because it needs your operating system.
http://www.brother-usa.com/downloads/Default.aspx?ProductGroupID=1&ProductID=HL2040
Posted on Apr 05, 2010
  • 31 Answers
SOURCE: HL-2040 Laser Printer: Brother HL-2040 Laser Printer Dos printing...
use PRN command to print
Posted on May 06, 2010
  • 114 Answers
SOURCE: HL-5250DN Laser Printer: We have a brother 5250 laser printer. Trying to...
The problem coming because there is some paper jam in side the printer. Remove the toner cartridge and look inside the printer for any paper jam.
I hope it will help to solve your printer problem.
Posted on Jul 21, 2010
Dcp7065dnerror71 plz solution
  • Customer support from Brother
  • Phone Number
    800-284-4329
  • Talk to a Human
    Press 7 or Keep saying "Other"
  • Average Wait: 8 mins - 24 hours, 7 days
Contact Brother International Shortest Wait Best Support
Dec 26, 2014 | Brother Office Equipment & Supplies
Tip
Brother MFC laser printer facsimile machine replace drum or change drum soon...
OK so you have replaced the drum unit on your Brother, or you have not replaced it but your copies are fine and you want to extend the life of your drum unit.
Simply open the front cover.
Press the Options key on the control panel.
The display will show "REPLACE DRUM - 1.YES 2.NO".
Press 1 to reset the drum count.
Close the front cover.
This procedure wil work on the majority of the Brother MFC series of laser based Printer Scanner Fax Facsimile machines.
Good Luck and Thank You for using Fixya.
on Jun 03, 2010 | Office Equipment & Supplies
Laser Unit
Go To Below official Brother Forum Page For Your problem, HL 4570CDW Others Brother Solutions Center Still having Problem Then follow Us For
Brother Printer Support
Apr 01, 2014 | Brother MFC-9840CDW Laser Printer
Laser unit needs replacing
Open the Toner Cover
Press "Start"
enter 00
than the screen will show "Accepted"
after all, will be fine
Nov 27, 2013 | Brother MFC-9840CDW Laser Printer
HL-5250 report shows fuser and laser life at 0% and PF kit 1 at 12%
The fuser is a separate component to the drum and toner in this printer. It has a much longer life than them but will run out eventually. Sadly a fuser unit is not a commercially available consumable for this printer either. I would recommend contatcing a printer technicain or Brother directly for a quote on replacing this part.
Apr 12, 2013 | Brother HL 5250DN Laser Printer
The fuser unit is not a commercially available consumable for this printer. I would recommend contacting a printer technician or Brother directly for a quote on replacing this part.
Apr 12, 2013 | Brother HL-2070N Laser Printer
My brother DCP 7055 shows eror replace toner
Some Brother laser printers have separate consumables - the toner cartridge and the drum unit. From time to time you may need to replace only the drum unit and not the toner cartridge.
The error LED lights up, or an error message shows on a flat screen panel, when the drum unit is near the end of its working life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
Jul 26, 2012 | Brother 1 Black Genuine Laser Toner For...
My all-in-one printer keeps telling me that I need to change the drum soon. I bought a new drum inserted it into the printer and now I can't print anything. Plus, it is still telling me that I need to...
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Note
    Brother strongly recommends that customers do not use generic drum units and/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability. The Brother limited warranty does not apply to any problem that is caused by the use of unauthorized third party drum units, toner cartridges or toner.
    If you are using a genuine Brother drum and toner and after following this procedure the unit continues to show "CHANGE DRUM SOON", your machine may require service. Please contact the Customer Service Center.
May 01, 2010 | Brother MFC 7420 All-In-One Laser Printer
Brother hl 2460 showing error E51 please help
mulfunction of laser beam detector,
turn off the printer wait for a few seconds if still remain - replace laser unit.
Dec 27, 2009 | Brother HL 2460 Laser Printer
Paper Crinkling
you change your printer fuser unite solve it
May 29, 2009 | Brother HL-6050DN Laser Printer
76 people viewed this question
k24674
Marvin
Marvin
