Cell Phones Logo
A
Anonymous Posted on Aug 21, 2014
Zte firmware how to do a system update
Christina Walker
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 6 Answers
  • Posted on Dec 02, 2016
Christina Walker
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
6
Questions
0
Helped
4434
Points
13
First, open the Settings screen and tap Apps. Swipe to the left to access the All section, then scroll down, locate the Google Services Framework application, and tap it. Tap Force stop, and then tap Clear data. Go back into the System Update screen
KittyKait The Cat Lover
Level 1:
New Friend:
  • Contributor 1 Answer
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
423
Points
How do i remove firmware system download off my zte fanfare android phone
3answers
How do i take ZTE Max out of recovery mode?
try googling for firmware of zte max put it in memory card and install from there.
My zte z828 phone wont turn on theres a red light on
Try install new firmware
Frist go to imei.info
And check the chipest your cpu
Then search in google ( zte z828 stock firmware )
Follow steps and your device will be alive again
Can anyone tell me how to upgrade the firmware on my android ZTE 750C Savvy?
Almost all current Androids are the same for updates. From the main screen go into Settings > Software Update. You should see a screen that gives you the phone's current software version and a button for checking for updates. If you select About Phone from the Settings screen you should see options for the hardware itself including the kernal and hardware version.
Most manufacturer's have the phones by default periodically checking for and applying updates - including the phone's firmware, so you usually don't have to worry about it.
How do I fix my phone if I get the message" Not registered on Network"
There may be few possibilities like the network not recognized,
locked with some other network,firmware not updated etc...
Network Not Recognized:
First, go to Settings-->Then go to Wireless and networks.-->Then Tap Mobile Networks (If mobile networks not found then tap More settings and then find and tap Mobile networks).-->Now tap Networks operators.-->After complete searching.... Then select your Network Operator (Like Vodafone, Idea, AirTel, etc.)
That's it, problem solved.
Locked with someother Network:
I suggest you can approach Simpleunlocking.com and specify the country,locked network of ZTE .Based on the availability you can get the permanent unlock code along with free instructions.
UN-updated firmware or software:
Select Software Update and Wait For It to reboot and Completed Update Completed!
Cannot make a phonecall, message is not registered on network
I suggest you can approach Prounlocking.com and specify the country,locked network of ZTE .Based on the availability you can get the permanent unlock code along with free instructions.
Toshiba e-Studio356SE firmware update failed?
Can anyone give me Toshiba e studio 355 firmware file? or a download link?
2answers
My telstra t54 tough phone has stopped storing the call logs
as per ZTE FAQ http://www.zte.com.au/telstra/faqs.htm this will give you a ZIP file to fix it.
Aug 15, 2011 • Cell Phones
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
