Why do i keep getting recovery (code108)but cannot get it to do anything
SOURCE: my archos 404 says to
Just convert the movie to MPEG4 ASP (Level 5), XviD, DivX 4, DivX 5 or WMV9 (max resolution of 704x 480 @ 30fps, 720 X 576 @ 25fps) format on your desktop computer an then load it onto Archos
SOURCE: archos 405
Hi fiona
I had the same problem as the archos web site is not the easiest to navigate.Have you actualy registered the product yet ?if so once logged in add your device as a product,on my products click on the picture of the 405 and that will take you to the screen for downloading archoslink (software to install the tv guide) and to the subscription page for down loading the tv guide.
How ever i have done all this and although i can download the guide i cannot sync it to my 405 so still unable to record off tv....Email gone to archos so fingers crossed....
SOURCE: archos 404 recovery code 2
i have an archos 404 the problem is that my archos show me the recovery code 4 to repair or format the disk so when ever i repair and format the disk the problem is solved. so please help me regarding this.
SOURCE: archos 605 wife (wife firmware)
If you chose any of these options already your Os is gone..
try this solution
I fixed my son's 605 4 GB had Recovery code
(104) on it. This might work for other error codes too. These are the steps i
followed
* Use the computer for this
process that you always used for this archos Archos should be plugged in to Pc
before starting the process.
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white option screen comes up pick the
format disk
* Wait until all done do not pick any option on
archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Safely remove the usb for Archos from your pc
first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by
holding it until it turns off
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this
time it will start Update you will see the progress bar moving, wait until it
is all done, it will shut off. Turn it back on and your archos will be back to normal
