I would suggest searching your Menus on the tv for the option to turn it off. Or search your manual.
most cases will have a parental lock on the chip which is set by the owner.
"Each television set’s V-Chip works a little differently. Once you understand the
definition of each rating and content label, programming and activating the V-Chip is
as simple as following the set-up procedure which can be found in one of two places:
1) the television on-screen menu options, or 2) the written instruction guide included in
the owner’s manual. The V-Chip will only be activated if you select the option to do so."
Pulled from this website:
http://controlyourtv.org/images/content/navigating.pdf
I hope this helps
