Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
The electronic display shows F-01 - Hotpoint Aquarius WD640 Front Load Washer/Dryer
Display shows Check Printer E 04 01
an E4-01 is a fuser warm up error...this is usually caused by a bad thermistor but can also be caused by a bad fuser lamp or thermostat
Apr 02, 2014 | Panasonic Workio Dp 8020e
Richo Aficio 3035 shows error SC865-01 What do I do?
the problem is with a electronic board, so nothing can be done by the used, the specific board need to be replaced.
Jan 14, 2013 | Ricoh Aficio 3045, 3035 Kit
I need restriction code for my x2-01
You can get the Nokia X2-01 Restriction code from the site Onlinegsmunlock.com/unlock-your-phone/rs7wp2/ and Unlock it easily...
Jun 28, 2012 | Nokia X2-01 cell phone T-mobile qwerty
NOT ASSIGNED CODE
NOT ASSIGNED means no cashier is signed on. Find the cashier number button, probably labeled CASH #. In REG mode, press CL to clear the error, then 1, then CASH #, and Cashier 1 will be assigned. The display will show -01- Go straight from here into your sale.
Some registers are set up to not show the cashier number on the display or receipt. If 1 CASH # doesn't work, try CASH #, 1, CASH #.
Most users don't track sales by cashiers, so they forget they even have the capability, and they forget how to use that CASH # key. If you press the CASH # button without entering a number, it will sign out the active cashier, and you'll get this NOT ASSIGNED error.
Jan 23, 2012 | Sharp XE-A402 Electronic Cash Register
My bosch dish washer won't work. A number 1 is displayed on the electronic panel. what does this mean Paul
Helloduranjp,
Welcome to fixya.
You said, Your Bosch dish washer won't work. A number 1 is displayed on the electronic panel.
If it is displaying"01" then that means the extra dry setting is being applied!
Did you try to use the extra Dry setting?
Did the dishwasher work before this or is it brand new?
What is the model number and year?
Let me know ! I'm waiting for your response
Below is and example of the usage of 01 or 00 in a Bosch Dishwasher!
Extra Dry Heat
With this option you can raise the temperature of the rinse water and increase the drying
time which will result in improved drying.
To activate :
Press and hold the left cancel drain button ,
Then press and hold the on/off button when the LED display shows a, "00" or a "01"
To enable the additional drying heat,press the left cancel drain button until the LED display shows a "01"
To disable the additional drying heat,press the left cancel drain button until the LED display shows a "00"
press the on/off button to save the settings.
Huuum
Oct 02, 2008 | Bosch Dishwashers
Descaling
There is a software Problem on the electronic in the back of the coffee maschine.
Changing that electronic to the new version will sort that Problem.
Mr. Cool
Sep 07, 2008 | Miele CVA4070 Coffee Maker
KENMORE ELITE OASIS HE CANYON CAPACITY DRYER
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information. This model is manufactured by Whirlpool, so maybe you can locate your model's failure codes.
http://www.repairclinic.com/0078.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 21, 2008 | Kenmore 67082 Electric Dryer
Change the time
Depending on the software of the Norstar it is connected to, you would log in to the key system by using Feature **23646 and then follow it up with the administration password.
If this is a pre 1.0 system, i.e DR5.1 do the following. If not, go to the bottom and click on the link and find the manual for the system your phone is connected to. Generally the system coordinator guide will have what you are looking for.
Setting the date
Begin with the display showing
l.Sys speed dial
1. Press [NEXT] (second key from the top on right for a 7310) twice.
2. The display shows 3.Time and date.
3. Press [SHOW] (first key on the top on the right for a 7310)
The display shows the time, for example, Time 01:00.
- All times and dates must be entered using numerals. For
example, February would be entered as “2”.
- The time may be entered in either 12 or 24-hour format. If the
display is in English, and the hour entered is less than
thirteen, the display prompts you to specify “am” or “pm”.
Press [Show] This will open the time change function. Simple rule. If you want to modify a value, press [CHANGE] and you'll get a cursor. Once you're done with that entry, press [NEXT] to go to the Minutes, press [CHANGE] etc...
I have also included how to change the date below.
Press [Next].
The display shows the date, for example, Date 31 Mar 91.
4. Press CHANGE (softkey under screen). The display shows Year: 88.
5. Set the year.
a. Press CHANGE.
A cursor replaces the number on the display.
b. Enter the year using the dial pad.
For example, press a a to enter the year 1990. ?
c . Press [Next] The display shows the month, for example Month: 01.
6. Set the month.
a. Press [CHANGE]
b. Enter the month using the dial pad.
For example, press 02 to enter February.
c . Press [Next].
The display shows the day, for example Dar: 01.
7. Set the date.
a. Press CHANGE
: A cursor replaces the number on the display.
b.” Enter the date using the dial pad.
For example, press 14.
Apr 03, 2008 | NorStar M7324 Telephone
Setting date/time display
First, you have to Enable Customer Programming. - With handset on-hook, dial #06. The display shows [MMC DISABLED]. - Dial the passcode and '1' and then dial #. (If you don't know the password try 1234, 4321, 9999, etc.) At this point, customer programming is open... Next, Setting the date and time. - Dial #55. Display shows [YY MM DD W HH MM]. - Dial new information as follows: YY = Last two digits of the year MM = Month (01-12) DD = Day of the month (01-31) W = Day of the week (1-7; week begins on Monday (1) and ends on Sunday (7)) HH = Hour (use 24 hour clock) MM = Minutes (00-59) - Dial # to set current date and time. The phone returns to normal use.
Oct 30, 2006 | Samsung Prostar 816 Phone
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
53 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
