Fedders AEP09D2BCOM Portable Air Conditioner Logo
A
Anonymous Posted on Aug 20, 2014
Why does condensation cup fills up in 30 minutes
william simpson
Level 3:
Genius:
  • Fedders Master 1,363 Answers
  • Posted on Sep 13, 2015
william simpson
Fedders Master
Level 3:
Genius:
Answers
1363
Questions
14
Helped
317833
Points
1636
It all depends on the humidity it's working in. more humidity the more moisture removed from air.
1helpful
Instructions manual for Gordon Ramsay slow cooker CGRSCT002
You don't need to fill with water. Use a cup of water mixed with 1/4 cup of vinegar. Use a sponge and let it sit 30 minutes min. Go back here & there and keep damping the white vinegar mixed with hot or warm water. Rinse well and dry with a paper towel.
tip
ICAPP-4 - A Wiki Manual
Cuisinart ICAPP-4 – Iced Cappucino and Hot Espresso Maker – A Wiki Manual
By Tha Mp3 Doctor (who also loves Cuisinart)
Since I am not well-versed in the copyright laws regarding reprinting copies of standard user’s manuals online, I am writing this Wiki Manual for the ICAPP-4. My unit is 12 years old (in 2009) and continues to run strong through two different owners.
General Directions for Making Iced Cappuccinos
- Place carafe on top of drip/tray grate with handle touching right front of ICAPP – the ice fill lines should be visible when looking at front of unit
- Turn “milk knob” to OPEN position, and open lid of ICAPP
- Remove milk container, espresso collector, espresso spinner cup and cover
- Put espresso collector back in place with two plastic teeth facing front of machine
- There is a stepped fill line inside water reservoir that measures off 1,2, and 4 cups
- Fill water reservoir with either 1,2 or 4 fill line cups – do not overfill to avoid damaging the electronics
- Add espresso grounds to espresso spinner cup
- Line up teeth of spinner cup cover with spinner cup so that the cover locks into place
- Fill milk reservoir with 3 oz of milk per cup of iced cappuccino that you plan to make – there is a fill line that measures off 2 cups or 4 cups
- Fill carafe with either 2 cups worth of ice or 4 cups, depending on how much iced cappuccino you plan to make
- Press down on lid and turn milk knob to HEAT postion
- Turn ICAPP on using the ON/OFF button – it will begin to heat – takes about 5-6 minutes (HEAT light will stay on during this process – doesn’t make noise or steam for several minutes)
- When READY light turns green, turn the milk knob to the DISPENSE MILK position – your espresso and milk will start dispensing
- Unit turns itself off automatically when ready – takes several minutes
on Feb 25, 2009 • Cuisinart ICAPP-4
I need insturctions on using the avon rice cooker for microwave
1. Before cooking, optionally rinse or soak the rice. This is necessary for some types of rice (especially brown rice, which is much harder than white rice), but it improves the flavor and texture of most types. To rinse, put the desired amount of dry rice in a container and fill it up with cold water. Use clean hands to sift the rice in the water. Drain and repeat. To soak, put the desired amount of dry rice in a container and fill it up with cold water. Let stand for 30 minutes, and then drain.
2.Mix rice and water in a microwave-safe container. A good place to start is two parts water for every part of rice (e.g., 2 cups rice to 4 cups water). You can adjust the ratio through experimentation, depending on how dry or moist you prefer your rice, the power of your microwave and the size/shape of the container.
3.Enhance the rice with flavor. Add salt, vegetable oil, olive oil or butter before cooking. A teaspoon of salt/vegetable oil or 1/2 tablespoon of butter should do the trick for each cup of rice.
4. Stir the rice mixture slowly with a wooden spoon. Combine the ingredients thoroughly. This is especially important if you have added other ingredients for flavoring.
5.Cover the rice. Place in the microwave and set the timer. Here are some suggested guidelines for a 700 watt microwave and white rice:
  • 1/2 cup rice, 9 minutes
  • 3/4 cup rice, 12 minutes
  • 1 cup rice, 16 minutes
  • 1 1/4 cups rice, 20 minutes
  • 1 1/2 cups rice, 23 minutes6
6. For brown rice, start with three cups of boiling water per cup of rice and cook it for 25 minutes
7. Let the rice sit in the microwave for five minutes after it turns off. Don't open the door. The steam will complete the cooking process. You might observe that the rice grains start to orient themselves vertically, like they're "saluting".
8. Fluff the rice with a fork and serve.
hop you enjoy it
Machine takes a long time for first cup to come out then sometimes only half as much water as used to comes out
mcdevito75 here, sounds like your coffee maker needs cleaning, after 20--30 cups of coffee made it does. Fill the decanter with white vinegar, clean or place new filter in the machine and cycle the white vinegar thru 3 times, on the 3rd time time thru stop the machine for 30 minutes, then resume that cycle. Now clean or replace the filter again and cycle thru regular water 3--4 times the get rid of all the vinegar, machine shouls be fine now.
It doesn't give full cups now and seems very strong. We did descale it, but it still is not right. We do get full cups of hot water though
tell ya little secret run a cup of bleach and fill the reast of the way with water let stand for about 20-30 minutes then turn it on and run it through your check valve in the element is stuck with just **** or calcuim
Water filter initiation failed
Did you this steps?
Fill the tank with fresh water.
Let the filter soak for 30 minutes.
After 30 minutes discard the water in the tank and refill with fresh water.
Place a container under the spout.
Press the cup button in the middle.(Filter on, yes)
Press the cup button again.(press ok, initialisation)
The machine initialises the filter.
Press the cup button again.(done initialisation)
Then press MENU repeatly. When the "exit" message is displayed, press the cup button. In this way, the machine ends the start-up phase.
Best regards
/Mirran
Walter initiation failed
Did you this steps?
Best regards
/Mirran
26helpful
2answers
Directions on how to use my Black and Decker Espresso Mio coffee maker
Be sure the red rubber gasket is in place and clean (ridge side in) and bottom water cup is screwed firmly on to avoid leaking.
HOW TO USE:
1) Fill the bottom water cup with cold water up to the inside lip.
2) Set funnel into bottom water cup
3) Fill coffee basket with expresso grind coffee and level off. (Do not tamp or pack). Make sure it's filled to the top.
4) Place filter onto coffee basket and set coffee basket into funnel
5) Place brewer over bottom water cup and screw firmly into place.
6) Place unit with lid in the center of a microwave oven set on high for 1-1/2 minutes. If boil over occurs, reduce the brew time in 10-second increments until no boil over occurs.
7) Grasp handle to remove unit from microwave when finished brewing.
8) Remove lid and check the level of espresso in the brewer cup. Standard brew is at least 2 oz. If you don't have this level brew, replace lid and microwave on high another 10 seconds. Wait 20-30 seconds for bubbling to stop.
CLEANING/ADDITIONAL BREWING:
1. Under cold running water, unscrew the bottom water cup. CAUTION: It is normal for some water to be left in the bottom water cup. Both the coffee basket and any water in the bottom water cup will be extremely hot! If you prefer, allow the unit to cool for at least 3 minutes before unscrewing it.
2) To brew additional espresso, rinse Funnel, coffee basket and filter, then repeat brewing steps 1-8 above.
3) Parts are top rack dishwasher-safe -- hand washing filter is recommended.
45helpful
5answers
Rival automatic steamer rice cooker 4450 guide needed
Here's all the info I've been able to find:
The older Rival rice cooker steamer should have a base, a lid, steamer basket, and rice bowl.
To cook rice, fill center basin of base with water. Place the rice bowl on basin. Add rice and water as follows. For white rice add water in a 1:1 ratio to rice plus 1/2 cup. For brown rice add water in a 1:1 ratio to rice plus 3/4 cup. Examples: 1 cup white rice, 1-1/2 cup water; 2 cups brown rice, 2-3/4 cups water. Put lid on and plug in and in about 50 minutes you should have delicious rice.
Timing is Everything
Whether using the Rival Steamer for a main dish or for a side dish, cooking is easy. But not Fast. Rice and steamed vegetables actually take twice as long to cook in this steamer. The simplicity comes since you add your rice or vegetables in one step. No waiting for one thing to happen before you can do the next. Put water and fruits, vegetables, fish, poultry or rice in the basket or bowl that come with the unit, cover, plug in and wait for the light to go off per the timing chart.
1/4 cup water takes 6 -7 minutes
1/2 cup water takes 10-12 minutes
3/4 cup water takes 16-17 minutes
1 cup water takes 19-22 minutes
1.25 cups water takes 24-26 minutes
1.5 cups water takes 26-30 minutes
2 cups water takes 38-39 minutes
2.5 cups water takes 43-44 minutes
3 cups water (max fill) takes 45-50 minutes.
Steamed Chocolate Pudding (From the Rival Steamer Guide)
3/4 cup flour
3/4 teaspoon baking powder
1/4 teaspoon salt
1/3 cup butter
1 teaspoon vanilla
1/2 cup sugar
1 egg, beaten
1.5 ounces unsweetened chocolate, melted
1/2 cup milk
1/4 cup chopped nuts
Sift together flour, baking powder and salt; set aside. Cream butter and vanilla until fluffy. Gradually add sugar, beat well. Add egg and melted chocolate; blend well. Add milk alternately with dry ingredients and beat until smooth. Fold nuts into batter. Pour into greased 8"x4" loaf pan. Cover pan with aluminum foil. Place pan in steamer basket. Cover and steam until wooden pick inserted near center comes out clean. Serve warm with **Marshmallow Cream Sauce. Water: 1 cup. Time: 19-22 min.
**Marshmallow Cream Sauce:
16 large marshmallows
1/3 cup cream
In a small saucepan, combine ingredients and melt over low heat. Serve over Steamed Chocolate Pudding.
Top Fedders Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
