Inverter KEB COMBIVERT F5 Logo
A
Anonymous Posted on Aug 20, 2014
Ow do i fix error 59 - Inverter KEB COMBIVERT F5
mntech1
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
New Friend:
  • Inverter Expert 120 Answers
  • Posted on Aug 22, 2014
mntech1
Inverter Expert
Level 2:
Mentor:
New Friend:
Answers
120
Questions
0
Helped
78050
Points
185
If you are talking about error code 59 then the error is E.HybC.
E.HybC means that the feedback card on the inverter has been changed.
You must confirm the change at parameter ec.0 or ec.10. The inverter reads the value from the feedback card so all you have to do it hit enter to confirm the value.
If you have not changed the feedback card but the error continues to come back then there is a problem with the feedback card or the control card.
2answers
Hp color LaserJet cp2025 59.c0 error how to fix it
59 errors indicate one of the motors have failed. It could be a bad motor but also a bad cartridge will overload a motor and cause the error as well. If you have spare cartridges, try changing them one at a time and restart between changes to see if the error goes away. Also if the error only happens when you start to print it might be the fuser motor.
59.9 Error turn off then on
1. Turn the printer off, and then turn the printer on.
2. Check and reseat the fuser and toner cartridge to make sure they are not hindering gear movement in the drive train.
3. Check the main motor's cable to ensure that it is seated properly.
4. Replace the main motor.
More Info... Hp Error Code 59 Service Repair Errors 59 Fix Codes Message And...HP Printer Support
Thanks,
2answers
When i sand a test page the printer show an error 59.f0 what can i do
Pull the transfer unit out, and turn the white gear on the side. Not the one that turns the transfer belt--the one that causes the belt to push up against the toner cartridges. If the gear turns somewhat freely (it's not stuck), then reseat the transfer unit and see if the error goes away.
More comprehensive troubleshooting guide is here:
http://www.partsondemand.co.nz/uploads/97806/files/Feb_14_59.F0_error_Tech_Talk.pdf
But if it passes all the "checks" and you still have the error, check this out:
http://cincinnatiprinterrepair.com/hp-cp3525-59-f0
6helpful
Error 59 co in 5550DN
Hello thanks for using fixya
59 C0 error code usually affects the printer motor. The problem can range from a couple of issues that occur within the printer's motor. It can also be a cartridge issue. Depending on the printer and which manual the user is referring to, the solution to fix this error varies.
  1. Error code 59 C0 due to problems with printer motor
  2. Error code 59 C0 due to problems with cartridges
  3. Error code 59 C0 due to broken back sliding lock
Error code 59 C0 due to problems with printer motor:
This is referred to as "developing disengaging motor rotation error" Most likely, this problem points to an issue with the function of the DC controller either it has failed or it has affected the developing disengaging assembly.The solution is quite simple and you may fix the error in a matter of few steps.
The first step is to reconnect the J16 connectors that are used for the developing disengaging motor to the J1100 connectors that are used for the DC controller PCB (that is the printer circuit board of the DC controller).After connecting these two connectors to each other,you must replace the developing disengaging drive assembly directly.The final step is to replace the DC controller PCB, after which the printer is to be recalibrated.
Error code 59 C0 due to problems with cartridges:
Another more complex problem that leads to the 59 C0 error code is a problem with the cartridges.You must first remove all the printer cartridges in order to view the right swing guide. Once these have been removed, you must check for certain parts in the printer, which mostly resemble upside-down. If you finds that the swing guide does not move all the way backwards,then the most likely problem is a missing plastic component of the swing guide. This part also resembles an upside-down T.
Another problem that may cause the error to display is when the black sliding lock is broken out of place or missing its spring. If any of these cases, you must replace the swing guide completely. You should attempt to locate the missing piece within the printer so that it does not cause further problems in it. If the swing guide does function properly, then gently close the door, paying close attention to the right side of the printer's swing arm.If the right side swing arm closes in the same manner as the left side swing arm, then your printer is functioning just fine and you may simply need to turn it off to fix the error.If the right swing arm does not close properly, then the machine should be serviced by a professional to fix the problem.
I hope this solution will helpful 4 u
Please keep thumbs up in do Rating if it is helpful
THANKS & Keep Using fixya
How can i fix hp3600 59.Fo error
59.X PRINTER ERROR A main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation error 1. Turn the printer off, and then turn the printer on. 2. Check and reseat the fuser and toner cartridge to make sure they are not hindering gear movement in the drive train. 3. Check the main motor’s cable to ensure that it is seated properly. 4. If the error persists, replace the main motor.
73helpful
7answers
HP 5500n 59.ck error code
HP LASER PRINTER 2300 ERROR 59.B, 59.C
1. The Alienation motor error.
2. Replace the alienation motor.
3. Replace the D.C. controller board.
Top Inverter Electronics - Others Experts
Ngoro
john h
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
