Every time camera is powered up, the date/time must be reset!
The camera's internal date/time "backup" battery is supposed to maintain the date/time for about 3 weeks with the camera turned off. If the camera is not used for a longer period, the date/time will need to be reset. If you are having to reset sooner than that, it is likely that the internal battery (not user replacable on most models) has failed.
All digital cameras have a small, internal power source that maintains the internal date and time. Freshly charged or new batteries must remain in the camera for at least 24 hours to fully charge this power source.
If new batteries aren't charged for at least 24 hours, you must reset the date and time every time batteries are changed. After the power source is fully charged, it maintains the date and time under normal use.
http://support.en.kodak.com/app/answers/...
SOURCE: camera will not retain time setting
Firts check the state of the litium battery, this is locate near the Audio/video port in your camera, with small flat screw driver you will be able to remove it. If the same situation occur after replacing the litium battery and i'm assuming the unit had never be open before unfortunately your camera needs new main board ass'y. But if the case is that some one open the unit before check for a loose conector from the litium unit to the main board.
SOURCE: Camera resets DATE and Time to Jan 2002 when
Some of these cameras cannot save the date, and has no internal battery to save the data. The best solution I have use is to buy another battery with these kinds of cameras and always have one charging, or take two batteries when you take pictures.
These older point and shoot cameras are nice, and slower than the newer ones, but will not save the data unless you keep the main battery in it, or replace the one to be charged with another battery within a very short time.
SOURCE: Camera does not retain time & date when battery is removed.
HI there you camera internal CMOS battery is down need to replacement.
SOURCE: I am trying to set
You have to change the 'date battery'. Use the user manual to find its location.
Mine is Canon A520, located beside the cable link sockets. Battery is CR 1220.
SOURCE: My wife is complaining that
Sounds to me that there may be another battery inside the camera that is going bad.
Issue: Everytime I power on the camera the Date / Time needs to be set.
Solution: Replacing the Date Battery for the PowerShot A480.
Replacing the Date Battery.
If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
Please note that the first date battery may appear to expire relatively quickly after you purchase the camera. This is because it is installed in the camera at the point of manufacture, not when you make the purchase.
Be particularly careful to keep the date batteries out of the reach of children. Seek medical assistance immediately if a child swallows a battery since corrosive battery fluids can damage the stomach or intestinal walls.
1. Confirm that the camera power is turned off.
2. Open up the battery door / cover and remove the AA Batteries.
3. Remove the date/time battery holder.
4. Grasp the battery and slide it in the direction of the arrow.
5. Insert a new battery with the (+) side facing up.
6. Replace the battery holder and battery cover.
7. When the Date/Time menu appears set the date and time.
After purchasing the camera and turning on the power for the first time, although the Date/Time menu will appear, you do not need to replace the date battery.
If you ever dispose of your camera, first remove the date battery for recycling according to the recycling system of your area.
DATE/TIME
DATE/TIME
OKOK:At the time of purchase and after leaving the camera for a
long period with the batteries removed, settings such as the
date and time are cleared. Once the AC power adapter has
been connected or the batteries have been installed for 2
hours or more, the camera settings will be retained for
roughly 6 hours even if both sources of power are removed.
