SOURCE: pioneer AVH-P5000DVD
I am sorry to tell you, but this model is only set up for region 1.
I checked the service manual and it only gives region 1 as an option.
If you were able to change the region, it would give the other regions as possible options.
There are some DVD players that will let you change the region a couple of times before it would lock into a region, but this is not one of them.
I work at an authorized Pioneer repair center, so I have access to all of Pioneers service information. I have repaired a few of these exact models and never came across any menu functions that would allow you to change the region.
Despite the not so good news, a good rating would really be appreciated.
It motivates us to answer questions that may not have a very popular answer.
Have a great day and let me know if you need any further assistance.
SOURCE: can't get unit to come on !(pioneer avh-p5000dvd)
no you should have power to audio just not video with out parking break set. check for power to head unit.check head unit fuse.
SOURCE: radio avh p5000dvd no lee los cd y dvd
mandalo a un taller para que te le limpien el lazer y si no trabaja vas a tener que remplazar el laser.este es mi correo por si tienes dudas ([email protected])
SOURCE: Pioneer AVH-P5000DVD stereo USB Error 23
OK Guys , I was searching on the internet and I saw you have this problem and I know how to fix it so here is the solution :
1) download "HP USB Disk Storage Format" from this link :
http://www.mediafire.com/?mzgmyduwkme
OR
http://rapidshare.com/files/227406046/HP_USB_Disk_Storage_Format_Tool.exe
2) install it on your computer and insert your flash memory (memory stick or whatever) and run "HP USB Disk Storage Format"
3) in the HP USB Disk Storage Format window screen chose your device ( your flash memory ) and file system ( FAT32 ) and click on start button.
NOTE : ALL OF THE DATA IN FLASH MEMORY WILL ERASE !
4) when formating has finished, copy all musics and stuff in the flash memory and you'll be able to use your flash memory on any pioneer devices !
