Cars & Trucks Logo
Timothy Rigabar Posted on Aug 21, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tying to find crank sensor for 2002 Cadillac Seville std 4.6 liter
Archaeology
Level 3:
President:
  • Master 662 Answers
  • Posted on Jul 06, 2015
Archaeology
Master
Level 3:
President:
Answers
662
Questions
8
Helped
495966
Points
2068
This answer covers 1999-2005 Cadillac Deville, Eldorado & Seville.
Example Engine:
2002 Cadillac Seville STS 4.6L SFI DOHC HO 8cyl.
This engine has (2) Crankshaft Position (CKP) Sensors: the Upper sensor is CKP sensor B, and the lower sensor is CKP sensor A (this is included for the OBD-II DTC codes - P0385 references Sensor B = upper CKP sensor, whereas P0335 references the lower CKP sensor (sensor A)).
Both crankshaft position sensors are located in the front of the engine just above the oil filter adapter. To access both CKP sensors, jack up vehicle on the passenger side, remove the oil filter, and the oil filter adapter, including the Engine Oil Pressure (EOP) switch. See illustration.
Tying to find crank sensor for 2002 Cadillac - tying-find-crank-sensor-2002-cadillac-3hcuyyaerdphtgzyedxwn2k0-1-0.jpg
The ARROW points toward Front of Car.
1. Upper Crankshaft Position Sensor (B).
2. Lower Crankshaft Position Sensor (A)
3. Engine Oil Pressure (EOP) switch
4. Engine Oil Level switch
The Oil Filter is the can-type object below the oil filter adapter, which includes the EOP switch. Recommend: remove oil filter with an oil filter socket/strap wrench, since it's close to the oil pan.
Michael Anderson
Level 3:
  • Cars & Trucks Master 799 Answers
  • Posted on Aug 21, 2014
Michael Anderson
Level 3:
Answers
799
Questions
Helped
261918
Points
2237
1996 Cadillac Seville sedan. Where is the MAP sensor located please?
Question edited for clarity, add maker.
Question moved to model category.
MAP sensor location on 95 Concours
Cadillac Owners Forum https://www.cadillacforums.com > threads > map-sens...
Jul 2, 2020 - If you have the 4.6 Northstar engine the MAP sensor is pressed into the top of the throttlebody, usually on the left (front) side, ...
Location of the MAP sensor in a 1989 Brougham
Jul 9, 2013
MAP sensor 1984 DeVille - Cadillac Owners Forum
Apr 17, 2020
Where is the MAP sensor located ???? 84 Seville
Nov 27, 2005
Cadillac seville (1995 sls) revving itself, and has trouble ...
Jan 18, 2012
More results from www.cadillacforums.com
Q&A: Cadillac DeVille Starter Location, MAP Sensor ...
JustAnswer https://www.justanswer.com > Cadillac Repair
Feb 4, 2010 - Its on top of the intake manifold, here is a picture and instructions. Let me know if you have questions, thanks. graphic.
Crank sensor on a 2002 Cadillac Seville std
Should be under cranshaft pulley.
How to fix idle problem on cadillac 2001 sts Seville
When I purchased my brand new 2002 Cadillac SLS Seville, I had a problem with the ideling and also the car would lurch forward every time I put it in drive. I had the dealer replace the idiling chip and it fixed my idleing and lurching problem. You could try this and see if it fixes your problem, or check for recalls with this problem.
If your car stalls while ideling - then check the crank sensor.
It is also good if you purchase a scanner and check which codes are registered by the on-board computer and this could save you some money trying to determine the problem.
Hope this helps.
2helpful
Where is the crankshaft position sensor located on a1999 cadillac seville
For a 1999 seville the crank shaft sensor is located on the leftside of the engine right above the oil preasure switch, heres a diagram to help you locate them, this car has two cranksensors, cranksensor A and cranksensor B. hope this helps.0c1d494.gif
16helpful
Need to replace both crankshaft position sensors 2001 Cadillac
4.6 the twocrankshaft position sensors are located on the front of the block just above and to the left of the oil filter. not hard to replace.
1helpful
1993 seville automatic transmission V8 4.9 liter?
neither the 93 seville is just that it's the 4.9 liter before the northstar sts 4.6 came out in same year
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
