You've got three different problems there. Blurred lines could be a printer head problem. Colors are wrong suggests that at least one of your ink tanks may be out of ink now. Straight lines being misaligned means that you need to realign your head again.
Go into your Canon's menu and look for something like Maintenance. There should be an option to align heads in there, along with something that says Clean Nozzle or Jets. Try cleaning and see if that resolves your problem.
If this is a printer that's been sitting idle for some time, you might need to clean the printer head as well. Search YouTube for instructions on cleaning printer head and/or cartridge. You usually use alcohol on a Q-tip to do that.
SOURCE: blurred printing printer i255
Hi, check the nozzle and test , if the result not in solid color there are spaces within the color means need head cleaning after head cleaning twice test print .
SOURCE: Mp510 Canon - printing and
Greetings,
Well you already finished with head alignments.
And it's not straight even on Copy ? It needs service, the print head is busted and you can't buy a new head & replace it.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
SOURCE: colors print blurred
you need to run the nozzle deep cleaning utility, nozzle check and alignment procedure under the printer properties maintenance tab.
Please rate this solution. Thanks.
