Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer stopping mid-cycle
My Whirlpool Ultimate II washer stopped running mid-cycle. It won't work at all, and it's full of water. If I move the dial to rinse, etc., the machine makes a noise similar to an egg timer. What can I do to get it going again?
    President:
  • 3,113 Answers
Push down on lid. You may have a bad lid switch. Start machine and press the switch down with something like a screwdriver and see if the motor runs.
Posted on Jul 02, 2009
SOURCE:
Whirlpool Ultimate Care II Washer will not drain
bad lid switch,open the lid a few inches and close it down,if you do this a few times and don't hear a clicking sound the switch is bad.
http://www.youtube.com/watch?v=PZAbg9uftos
Jun 05, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
My whirlpool ultimate II washer was working fine and just stopped. I could smell something like wiring getting hot and now it won't do anything. The basket is still full of clothes and water.
remove the frame,pop off the two clips that hold the pump on and pull the pump off of the motor shaft,start the machine,if it runs you have something stuck in the pump.if it does run get a shop vac and remove the water from the tub,then remove the clamps on the hoses just push them down the hose with a pair of plyers then loosen one hose at a time so you can vac out the water,once you have all the water out you can remove the pump and see what's stuck in it,usually,a sock,womens underwear or a metal from a bra.if it's not the pump move the shaft on the motor with the plyers were the pump slides onto,you could have a flat spot on the motor and by moving the motor at the shaft might free it up,i've done this,some motors will run all the time after this or it could stop again on the next load,watch it and see what happens.http://www.youtube.com/user/RepairClinic?v=DwV71h86Gxw&feature=pyv&ad=5457341861&kw=washer%20pump
watch video and it will show you how to get at the pump and motor.good luck with your washer
Jan 23, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer stopped after wash cycle
The lid switch is the culprit. Push down on the lid it should start. It needs to be adjusted . the tab on the lid is not activating the switch. Try triming the door bumpers.
Apr 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer fills but won t advance to the next setting for all cycle
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool washer stops for no reason.
i would be concerned teh the door/lid switch is not being activated, or is loosing contact withthe swtch mid wash causing unit to shut off. unitll the lid is lifted and closed to make better contact.. tyhe activator for the lid switch is actually the underside of the lefthand lid hinge. so if your able toreah under the lid while open you feel the metal lever, as you push and pull hte lid youll feel the lever move as well. with a hollow shafted screwdriver/1/4 nutdriver. place the driver over the metallever andslightly bend it toward the rear of the uni, so it makes better contact with the switch mounted tothe underside of the main top assembly
Nov 20, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool ultimate care II will not spin
You said,washer is full of water and will not spin. You hear the lid switch clicking. When you start it on spin cycle and hear a hum, the tub moves a couple of inches and then stops...shortly after it shuts off.
Some reasons this may happen
Washer won’t drain or spin
n
1. Is the drain hose clogged, or the end of the drain hose
more than 72 inches (183 cm) above the floor?
2. Is the lid open? ............Also the lid switch can be faulty!!
The lid must be closed during operation.
3. Is there excessive sudsing?
Always measure detergent. Follow manufacturer’s directions.
4 If you have very soft water, you might need to use less
detergent.
Sounds to me like the lid switch can be faulty!!Then it acts like the lid is open.
Huuum
Oct 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
401 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
