Question about Life Fitness Exercise & Fitness
How do i get into the menu on life fitness 9500hr tradmill
  • Life Fitness Master
  • 918 Answers
Next Generation 9100, 9500HR, 9700HR, 9700HR with Decline Treadmills
  • Press and hold the "Pause" key while pressing the "Clear" key twice.
Hope this helps!
If anything else please visit us online
http://www.sportsmith.net/productsearch.aspx?dsNav=N:10598 or give us a call at 888-713-2880
Posted on Jun 09, 2015
5 Suggested Answers
SOURCE:
gymtech
  • 18 Answers
SOURCE: Hi! i have a life fitness 9500HR treadmill and it
Unplug the treadmill . Remove front cover. On the right hand side if you are facing the front - in the siderail is a white switch that tells the treadmill it is all the way down. Check that it is in place and clean.
If you plug the treadmill in.{Do not touch any thing in the motor compartment} When you press start it should go all the way down [home] to contact the switch. You can also see the lit motor turn at this time before the belt will move it must be all the way down.
Posted on Feb 09, 2010
gymtech
  • 18 Answers
SOURCE: The battery in my life fitness 9500hr has died.
What battery?
bwinton
  • 83 Answers
SOURCE: hi have life fitness 9500hr.when i opne MOTER
Every time I have gotten this message, I have had to replace the motor controller.
Posted on Mar 24, 2010
outfield502
  • 79 Answers
SOURCE: Sir, i have a life fitness
please check the fuse of 0.3 amp is located in the front of the machine revises this swicth home underneath the left side of the machine or check for side always in the left if the cables are not disconnected last step and check the capacitor is located on the hoist motor any question send me a message cardiotech_me@hotmail.com
Posted on Sep 15, 2010
Life fitness 9500hr treadmill belt not moving and speed sensor error comes up on the screen
see the video and lube to the rollers bearing front+back .
and Run the calibration software for easy diagnostic for s. sensor
God bless you
Oct 17, 2013 | Life Fitness 9500hr Next Generation next...
Treamill 9500hr is reading weight in pounds and not kg
Please go to the Menu, and go to the section go caractheristic and change the Lbs to Kgs.
God bless you
Jan 09, 2013 | Life Fitness 9500HR Next Generation...
How do i get the hours info from a life fitness 9500 hr elliptical
go to the MENU, and see the details.
However your must read your instr. manual and see how to enter.
God bless you
Dec 05, 2012 | Life Fitness 9500HR Next Generation...
How do I access the service menu on a lifefitness 9500HR treadmill?
To get to the service menu start by pressing the pause button and keep it held down as you hit the clear button twice. The treadmill will reset and go into the service menu, and now you quite pressing the pause button.
Mar 31, 2010 | Life Fitness 9500HR Next Generation...
Hi have life fitness 9500hr.when i opne MOTER
Feb 27, 2010 | Life Fitness 9500HR Next Generation...
Manual for lifefitness 9500hr treadmill old modle
Just call Life Fitness and they will send you one via e-mail attachment.
(800) 351-3737 between 8 a.m. and 5 p.m., CT Monday through Friday.
stephen
Aug 01, 2009 | Life Fitness 9500HR Next Generation...
It starts how ever after 2 minutes it stops and go back to the main menu
check for a little memory backup battery, probably a CR2032 located somewhere under the control panel.
Mar 26, 2009 | Life Fitness 9500HR Next Generation...
Heart rate monitor chest band not working with Life Fitness 9500H
This mean that you unit is not equiped with a receiver inside the treadmill. Some models that was an option. Polar is the only brand that works with Lifefitness. You may have a bad upper display board. You can buy a replacement for a small amount of money.
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Mar 12, 2009 | Life Fitness 9500HR Next Generation...
Exercise & Fitness Logo
137 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Vincent G
Vincent G
Craig Butler
Craig Butler
Android Man
Android Man
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
