If your Samsung washer is in the middle of a drain cycle and the 5E error code shows on your washers display, it means that the water is not properly draining out of the washer. Something may be clogged, jammed, or blocked and thus preventing water from draining out of the washer.
https://removeandreplace.com/2016/11/03/samsung-washer-displays-error-code-5e-message-how-to-clear-error/
That's actually a 5E error code. The 5E error code on most Samsung dishwashers means a drain error. Most often this is caused by a clogged drain hose, or some foreign object getting caught in the drain pump impeller. But it can also mean you have a bad ECS sensor if the drain pump and hose are okay.
The 5E error code on most Samsung dishwashers means a drain error. Most often this is caused by a clogged drain hose, or some foreign object getting caught in the drain pump impeller. But it can also mean you have a bad ECS sensor if the drain pump and hose check out okay.
ost common error codes that are caused by installation errors are:
5E. If your dishwasher is displaying error code 5E, It can be caused
by a kinked drain hose. A good indication that the drain hose is kinked
is excessive water in the bottom of your dishwasher after a cycle has been
completed. If your dishwasher is displaying error code 5E, your dishwasher
will have to be removed to inspect the drain hose for kinks. If your dishwasher
was professionally installed, contact the installer to remove the dishwasher
and inspect the drain hose. If you installed the dishwasher your self, the
dishwasher will have to be removed for drain hose inspection.
