Question about M-Audio Computers & Internet
How do you use yamaha mg82cx with m audio fast track?? Which cables go in the opical and line inputs on the card coming from the record out and line in's on mixer?? I am trying to record a radio commercial vo and have a mic pugged into mixer and and the sound card is connected to my compaq pc. I have done before but have forgot what goes where!!
2 Suggested Answers
SOURCE:
technical114
  • 1851 Answers
SOURCE: how to use yamaha mg102c with m audio usb
You must connect:
the mixer output to the "line|optical" input of the Transit
the mixer input to the line (in case of an analog signal) or to the optical (in case of a digital - optical signal)
The USB connector on the other side is going to be connected at the USB port of the pc.
Just keep in mind that the signal flow goes as the arrows on the Transit.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Posted on Feb 25, 2010
There is a 1 second delay from the time i play to
adjust your audio buffers, if your recording software allows it. however, there will always be some latency in usb recording devices. i recommend firewire or pci internal cards for recording.
Nov 30, 2009 | M-Audio Fast Track USB (FASTTRACK) Audio...
How to use yamaha mg102c with m audio usb
You must connect:
Thanks and regards
Stelios
Sep 05, 2009 | M-Audio Transit USB Sound Card
M-audio fast track sound only coming out of right side
I havent played with acid a lot... but this is what i can tell you... most of the softwares have configurable inputs... seems like your inputs are configured as stereo input and hence it will pick up the signal from both the left and right discreetly... which means that you would need to feed audio to both the channels for the meter to pump on both bars...The other option is to PAN the track center and not hard left right... this would get audio to both ears of headphone as well as the output meters...
these are basically some of the few things tht will get u sound on both ears and bars...
The bigger question here thoug is why do you want to record in stereo?? and not mono?
Jun 29, 2009 | M-Audio Fast Track USB (FASTTRACK) Audio...
No sound recognized in Audacity from Fast Track M-Audio
First thing is what operating system is on the computer.
Second is what does device manager say about the recording interface?
Third in audio properties from the task bar icon, what is the default device for recording?
Feb 23, 2018 | M-Audio Fast Track USB (FASTTRACK) Audio...
Using m-audio fast track usb with Behringer mixer
Use the taope outs. They're the RCA plugs located in your manual as "20".
Sep 01, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
Electronic drum kit, with USB out, problem
Sounds to me like you have the midi tracks outputting to the microsoft midi mapper or wavetable synth, which is built into the sound chip in your pc, and that this is conflicting with the mobilepre sound card - midi is just data, no audio, needs to drive some kind of synth. what you want to do is disable your internal sound card thru device manager, then just use the m-audio mobile pre as the input/output sound card in ASIO mode - you'll need to monitor via the headphone jack on the mobile pre or plug speakers into the line outs on the interface.
Then do tutorial 8 (in help files) on using soft synths - INSERT>SOFTSYNTHs creates a midi track and an audio track in a track folder.
Good luck.
The dude.
Aug 07, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
Taking recordings from mixing desk
As the Fastrack can only receive one audio signal at a time you would have to record each track seperatly into Pro Tools.
I'm guessing your mixer is a multitrack recorder.
Solo track 1 on the multitracker and playback from there into the Fastrack, with track 1 on Pro Tools set to record. Repeat this for each or your tracks on the multitracker.
When you've finished you'll need to align all the tracks in Pro Tools so they all playback in time with each other.
Jun 25, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
Computers & Internet Logo
66 people viewed this question
Top M-Audio Computers & Internet Experts
Edward Easley
Edward Easley
John Bolton
Thomas F. Schneider
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
