Samsung Galaxy Tab 8.9 WiFi 16GB Tablet Logo
A
Anonymous Posted on Aug 20, 2014
How to move files from tablet to sd card - Samsung Galaxy Tab 8.9 WiFi 16GB Tablet
fanaudi
Level 3:
  • Samsung Master 1,381 Answers
  • Posted on Dec 24, 2014
fanaudi
Samsung Master
Level 3:
Answers
1381
Questions
0
Helped
294795
Points
4199
Hi ,
I don't use the samsung Galaxy : is the SD card part of the Tablet ? Otherwise , any tablet or smartphone can be connected to a pc, via usb , bluetooth , wifi ... and any sd card can also be connected to a pc , directly or via a card reader . The pc'OS ( Windows , Mac , Linux ) will easily copy all files from one to another .
Regards .
Moving pics to sd card that has available space but tablet says sd memory full.
available space does not mean that there will be much space. when putting sd card in any tablet, tablet reserve some memory to process. please explain how much memory left. also check any hidden files and icons from sd card.
We have a lenovo tab2 A8, with a 64 GB microSD card installed. With both netflix & amazon prime video, in options, there is no selection to download to the SD card instead of the internal storage.
First, go to Settings > Storage and check if the "Default write disk" is set to "SD card". Then go to Settings > Apps and swipe to the left until you get to "SD card". Below will be all the Apps that can be be moved to the external SD card. Click in the box on the right and another page will come up. About in the middle of the page will be "MOVE TO SD CARD" tab. Tap on it and wait until it finishes. Then go back and pick another App to move. You should be able to download apps directly to the external SD card. I haven't done that on this device and not all apps will download to the external SD card (the app maker can restrict downloads to only the internal memory. This tablet is one of the rare few Android devices that allow moving Apps to external memory.
2helpful
How to down load films to a 32 GB card Hudle2.Thanks
OK, to accomplish this you need 2 hings:
1. A micro sd card. (Which I gather you already have one)
2. File manager installed in your tablet.
Now, if the tablet support micro sd card, you are all set. Download the file manager, it could be Astro, ES File Explorer, etc...
Once installed, open the file manager. The tablet storage, which is known as internal storage, it is display as sdcard/storage (or sometimes as internal storage). Once you tap the internal storage, everything that is installed in your tablet will be display; (Android, DCIM, etc...) Now you need to look where are the pictures or films saved at. It is usually DCIM/Camera. Once you have found the pictures that you want to move or copy, long tap the films, depending on the file manager app, you must tap copy or move (NOTE: Since every file manager is different, some takes a little bit of extra steps, others requires for you to open a menu). Once you had chose to copy or to move it, look for the external sd card location, which will also be located at sd card/storage/ (32gb external storage) and choose this location to paste your films or pictures.
Another way is by using a computer. Make sure that you have all the drivers needed for the computer to recognize your tablet, you also need the usb charge cable. Once the computer recognize it when the tablet is plug in to the computer, open it by double clicking, there should be 2 storage display under the tablet folder: Internal storage and 32gb. external storage. Open the internal storage, look for where the films are saved (just like I explained with the file manager), choose the films that are to be move or copy, and jus drag and drop or press ctrl and C to copy, go to the external storage, open it and press ctrl and V to paste.
HELLO MY NAME IS ANDREA TILLMAN AND I WANTED TO KNOW HOW TO MOVE MY MUSIC AND VIDEOS TO MY SD CARD FROM MY TABLET PLEASE AND THANK YOU SO MUCH
Andrea, Check the attached links,instruction and guides on how to move vids. to SD card, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Galaxy Tab How do move photos videos and other files on my Samsung Galaxy...
Transfer pics to sd card from Samsung tablet
Moving files from the tablet main HD to the microSD card
File manager saying LOST DIR for my SD card
Your cel phone download path is the internal storage, modify the download path to SD card or move files to sd to gain space.
How to fix error downloading insufficient space on device but I have a 8gb microsd card with lots of room and nothing will download please help this is my second next book tablet I just want to fix th
Amber,
I think your problem may be due to it downloading into the internal memory of the tablet. There may be a way of moving the apps into the external micro sd card rather than deleting them.
From http://www.tomsguide.com/forum/id-2055729/set-downloaded-games-google-play-directly-external-card-samsung-galaxy-tab.html
" Go into settings, then to storage, then to used space, then to applications. In applications manager go to sd card there will be a list of your applicationsicon1.png, touch/click on each one individually and within each one that can be moved, is a box "move to sd card" touch that box and wala it is moved! To move pictures I reset the cameras auto storage to the sd card then moved all my other pictures to the camera file which then stored them on the sd card. I then deleted the pictures from the system memory. Hope this helps! "
Nextbook 7 troubleshooting
I figured it out smile.gif Apps that I downloaded I can move to SD card while apps that were pre-loaded on the tablet can't be moved to SD-Yet when I move downloaded apps I get back MB even with clean master.
Try also this site.
How to transfer files and apps from Android phone Android tablet to SD...
Uniden tablet says not enough memory on internal storage cannot complete download, what do i do
Put an SD card in it and transfer all your personal files music, video etc to it. the internal starage is full so make some space by selecting the music, video files and chosing 'Move to Ext SD Card.
Transfer data from galaxy 10.1 note to sd ext storeage
Go to the play store and download a file management app. Use the app to move the files. OR, connect to a PC and manually move the files to the SD card
Top Samsung Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
