Question about Samsung 40" 1080p 120Hz Slim LED Smart TV UN40ES6100F
Samsung calibration how do I get the "user settings" menue off the screen of my TV. Stations don't show. Searched the manual and found nothing.
2 Suggested Answers
SOURCE:
  • 98 Answers
SOURCE: No picture screen is blue
If you use RF cable, need to change brand new cable.
But, before that need chck the status of cable connector.
Posted on Feb 09, 2009
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Screen wont show cameras or record
Are you pressing menu button on the monitor or the DVR?
Your problem may not be the cameras, but between the DVR and the monitor. Found this on page Eng-19 of the user manual which I found on Samsung.com
This monitor was set to password lock when you purchase a new set. Therefore, you must first enter a 4 digit password to activate the On Screen Display... the default password is 4321. Not sure if that helps.
Dec 17, 2013 | Samsung SMT-190DN 8-Channel Security...
Radio stations
There is a radio option to recalibrate your touch screen. Please press the following three hard keys simultaneously RADIO/MEDIA, SEEK UP, NAV (AUDIO on REN). Once you begin to recalibrate the touch screen you must finish. Audio confirmation prompts are provided for each of the three points of calibration, one beep for the first, two for the second and three for the third. The calibration needs to be precise as possible and a PDA stylus would be recommended. The MyGIG radio requires the user to repress each calibration point to confirm the calibration process. A green crosshair indicates proper calibration.You must not start with the "+" but with the "+1", then goto "+2" and last to "+". Repeat this until all crosses are green and exit with pushing the menue or any other key. Done
Jul 20, 2012 | 2008 Dodge Grand Caravan
Screen of mobile phone Samsung F480T sometimes does not work at all, other times perfectly normal. Resetting by removing the battery seemsto correct temporarily.
Touch screen problem
If your touch screen is not working, there's just 2 major causes of such, either a hardware cause which might be either the phone falling on a hard object or in water which could damage the sensor board and either the screen is malfunctioning and needs to be calibrated.
If you can access the menu of the phone, i will advice you calibrate the screen first before you send it to a repair shop. There is no updates to download for such problem as updating the firmware of the phone would do nothing but change the settings of the phone.
To calibrate the screen, you will have to go to the phones menu, go to settings, then you select the calibrate screen, it will show you some stars to touch and once you touch them properly, then your screen will be able to work effectively.
But if you cannot access the menu because of the touch, then i will advice you send it off for repairs, and what to repair on the phone is the sensor board.
Hope this helps you.
May 23, 2011 | Samsung Cell Phones
What are the best settings for my samsung lcd tv 620 series
You only have the preset picture settings and the custom settings to use in the user menu.. Only your eyes can tell you what you like. The only other way to get a really killer picture is to have a Professional ISF Video Calibrator calibrate the set.
Apr 10, 2010 | Samsung LE40B650T2 40 in. Full HD Crystal...
Displays weak or no signal
To get any HDTV to work this is what you have to do;
CHANNEL section
1) Connect your antenna cable which you have done.
2) Go into the menu to the source option and select AIR/ANTENNA since you are using an antenna.
3) In the menu you will have to SCAN in the stations. This auto program will find all available stations.
Now you can watch tv by selecting the station you want.
The new generation of HDTV is different from the old analog sets. These have to be set up to work.
Exact information can be found in your Users Manual.
Feb 23, 2009 | Samsung Televison & Video
Tv stuck on zoom
Hi
Thanks for using FixYa. Please check your cable box settings first. Sometimes the remotes have a picture size button on them, and the in-laws could have pressed that by accident. Check the TV settings, press Menu Button & then go to WINDOW/IMAGE SIZE. Now select normal size.
Also check the settings of the converter box (if you are using it). The boxes also have a peculiar problem: Unless users manually change settings from show to show, the picture from many stations either won’t fill the screen, or it will be so big that part of the picture is cut off by the edges of the screen. The solution is to press the “zoom” button on the remote that comes with the converter box. That will expand the picture so it fills the screen. If still the issue persists, then you’ll need to go to the service menu. To go to the service menu please start with the TV off and press mute > 1 > 8 > 2 > power the remote on. Now the TV will come on with the menu displayed and from there you can change the settings as required.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 27, 2008 | Televison & Video
Changing the time
Press "HOME MENU" select "INITIAL SETUP" and advance forward to "CLOCK SETTING'.
Enter your time manually OR
Select * "AUTO"
*Some stations embed the proper time within the transmitted signal. Your Pioneer will calibrate it's clock according to your local studio time.
I found a full users manual online and I looked for a place to post it here, but I found no place to do so. Sorry.
Hope this helps!
Apr 22, 2008 | Pioneer DVR-540HX DVD Recorder/HDD...
Samsung 40" 1080p 120Hz Slim LED Smart TV UN40ES6100F Logo
23 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
