Question about Moen 24 In. Towel Bar...
How to remove a towel bar with slot in bottom no set screw
    New Friend:
  • 4 Answers
There is no screw here.
Insert a small flat screwdriver -- small enough to fit fully in the hole -- and pivit it up, so that the tip presses toward the wall. This should easily release the locking tab.
Posted on Aug 24, 2015
    New Friend:
Mine didn't snap or turn off. It slid up after applying pressure to the tab inside the slot
Posted on Apr 04, 2019
    New Friend:
  • 93 Answers
Inside the slot there is a tiny set screw May be slotted head or allen screw .
Posted on Aug 29, 2014
4 Suggested Answers
SOURCE:
ldeambrose
SOURCE: How to remove towel bars and hooks from wall. No
Newer towel bars don't have set screws... Solution-slide off! There is an opening in the bottom of the bracket. Slide your flat head screw driver inside the opening and place pressure on the bottom. Make sure you place enough pressure to allow the holder to slide off.. Now pull on the holder and it will snap off...
Posted on Sep 07, 2012
  • 21945 Answers
SOURCE: Tighten up a loose Moen Eva towel bar wall mounted bracket
u have to really push hard up on the spring and at the same time pull towards u
Posted on Apr 18, 2010
agent91
  • 2100 Answers
SOURCE: how do i remove a
I think you grab hold of the rosette closest to the wall and spin it off, it should expose the set screw. If that isn't it, one of those things will turn. Try a few different spots. hope this helps.
Posted on Mar 20, 2011
How do you remove the eva towel rack holder
The Moen YB2824 is attached to the mounting bracket with a set screw through the base. You would simply need to loosen this set screw to remove item from the wall.
May 07, 2011 | Moen YB2818 Eva Towel Bar Bathroom...
How do i remove a towel bar that does not have a set screw on the flange cover?
Mar 20, 2011 | Moen 24 In. Towel Bar...
How do I remove a Moen Brantford towel bar from the wall. it does not have set screws but appears to have some type of slot/clip arrangement. it is a brushed nickel 18 inch bar. The only one I can find...
Same problem. The key to releasing it is finding the 'latch' of the 'spring'. I wish I could upload a photo. It just snaps off the way the battery compartment opens on your TV remote. On a TV remote if you apply too much pressure then you break the 'latch' on the battery's door, as we all know it is about applying pressure it the right place of the 'spring'. Once I got the correct placement of the flat head screw driver it was easy, but it took me 30 minutes to figure that out and I broke a piece of the towel rack.
Feb 22, 2011 | Moen YB2818 Eva Towel Bar Bathroom...
I need to remove a Moen towel bar. It has a tab under the bottom but I dont know what to do
There should be a "set-screw" (a very small screw) at the bottom of base (fat part) of the towel bar. It screws in to hold the fat part of the bar to the "tab". Loosen the screw by turning it counter-clock-wise. Once loose, the towel bar will lift off the tab. Be careful not to lose the screw!
Feb 21, 2011 | Moen YB8086 Mason Towel Ring Bathroom...
How to remove towel bars and hooks from wall. No set screw visible. We did not install them.
Sep 23, 2010 | Moen 24 In. Towel Bar...
Apr 18, 2010 | Moen YB2818 Eva Towel Bar Bathroom...
The towel bar just fell apart. The wall mounts remain in tact as well as the mounting hardware on 1 side (the piece that the bars (this towel rack has 2 bars) slide into. I can't figure out what holds...
The part that holds the bar up should either have a screw in the bottom to tighten up against the wall bracket or a hole to access a scew and turn the screw out to tighten to the wall bracket
Jun 20, 2009 | Gatco & Channel& Satin Nickel Towel Bar
Dell 2001 fp back panel removal ?
First remove the four screws behind the stand mount on the monitor. Then turn monitor vertically so thet the bottom is up. Next look for slots betweem the portions of the srame on the bottom. Use a slotted screw driver to pry open the bottom. Becareful to not damage the plastic. As bottom is opening pry around the entire frame it will come loose. Make sure you place the monitor on a table covered with a towel in the final process to un clip the case.
Herm Hart
Jan 10, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
How to Install Towel Bar?
Since towel bars are usually installed onto separate hardware that's mounted on the walls, use the actual hardware as a template to mark exactly where to drill your mounting holes. Hold a piece of mounting hardware against the masking tape and use your pencil to mark the actual spots to drill your holes. Use different-sized drill bits to drill for the two ends. The Molly bolt or wall anchor will require a much larger diameter hole than the screws going directly into the stud. (The size of the hole required for the wall fastener will be marked on the packaging.) Install the wall fastener into the wall, then mount the hardware onto the wall and place the ends of the towel bar over the hardware. Attach the towel bar to the mounting hardware using the screws included with the towel bar. These are commonly small-slotted screws located on the bottom of the end pieces of the towel bar.
Aug 27, 2008 | Grohe 40.344.000 Essentials Bathroom...
Whirlpool GD5SHAXKQ00 Ice/Water dispenser
Hey,
It's pretty easy to remove by yourself. DO NOT force it or it will probably break. Nice and easy will do it. You'll need a flat headed screw-driver and a towel.
-There are 4 retaining tabs. 2 on top and 2 on the bottom.
-Remove the drip tray in the dispenser area
-Start with the bottom. Before starting, look underneath the surround (yes--bend down, stoop or lie on the floor -- your preference) You will see 2 thin slots. That's exactly where the tabs are. Do one tab at a time.
-Place the folded towel under the surround at the same time you are placing the screwdriver tip gently at the slot---DON'T apply pressure to the screw-driver yet.
(The towel will protect the paint and by being folded will provide a slight leverage for the screwdriver) Hold the towel against the door with the same hand you're holding the screw-driver with. If you can't....then cry for help.
-With your free hand press down firmly on the lower part of the surround (where you removed drip tray from) ...at the same time GENTLY pry with the screw-driver.
It shout pop out pretty easily.
-Repeat for the other bottom tab.
-For the top tabs, lift the entire surround up and then out.
-Remove the wiring harness and VOILA!!!
-Show off to your wife.
Dec 28, 2007 | Whirlpool Gold White-on-White 21.9 cu. ft....
Moen 24 In. Towel Bar... Logo
8,885 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
