SOURCE: CANON MP730 ERROR MESSAGE 343 WASTE INK FULL
1-press the "menu" key
2-press the"copy" key
3-press the"#" key
scroll thru the menu heading until you come to "counter"
press "ok"
press "menu"
and select "clear all" it will ask you to "please wait"
then press menu two times
restart your printer
it will work
SOURCE: How to fix a message: Waste Ink Near Full
Instructions for resetting the MP730 ink tank full counter
1) Enter SERVICE MODE.By
pressing MenuCopy#
2) Select TEST MODE. using the + key then the set
3) Select [8] PRINTER TEST in TEST MODE. by hitting the number 8
4) Select 3. [EEPROM CLEAR]. by hitting the number 3
5) Select 0. [INK COUNT]. by hitting the number 0
6) Let it default to the new value by waiting
7) Press the [Stop/Reset] key (returning to the state of 3)), this is the red stop key
8) Then press the [ON/OFF] key and the machine will reset and push through a page of paper
Sometimes is need to clean the purge unit
Canon MP730 Printer Purge Unit Disassembly and Assembly :
http://newsquaremusic.com/CanonMP730PrinterPurgeUnitDisassemblyandAssembly.pdf
http://newsquaremusic.com/CanonMP730PrinterWasteInkTankFullResolution.pdf
I hope this is useful
SOURCE: how do I change the waste ink absorber in a canon ink jet printer
Hi you can try this.
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Can only try then your printer go on longer but some time the other you need to clean out the waste ink it inside the printer go to open up all.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: canon multipass mp730 / waste ink near full
Ok try using the codes
2. Hit "Copy" Key
3. Hit "#" Key
6. Hit "0" button
SOURCE: Waste ink near full - how do I empty it?
Hi
This works on the F30, F60, and F80.
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Skip step (6) since there is no [OK] key on F30 printers.
