Canon pixma mp198 can print and copy but cannot scan. It says cannot communicate with scanner. Cable maybe disconnected. Check status
SOURCE: CANON Pixma MP510
Check the shipping lock is off- consult the manual. Tell us the operating system you are working with.
SOURCE: Canon mp610 scanning problem
The readme says that some USB hubs have an issue.
I was having problems and was connected via a hub. I removed the hub and connected the printer directly to the back of the PC and voila scanning is all good.
ALex.
SOURCE: PIXMA Cannon MP 130: Scanner Problem
You said the printer works, but does it work from windows sending it to the printer.
If it does, then there could be a few problems. You should start by looking at you printer under start-printer, you should see the printer and should show your model. I would make sure that the software
you installed for the printer was for the OS you are running Xp,vista and try to reinstall it.
Because of the one error you listed, driver failed. Most times you can just reinstall it again,and when it goes to the folder just have it overwrite the folder. If running vista, turn off UAC when installing drivers.
Then unplug the printer and plug it back in after you restarted the system from the install, and windows will see the printer.
Now maybe someone had the same problem that can give you better advise so just wait. But you can at least shut down your pc, unplug your printer, restart the system,plug in the printer and try it again,and if the problem remains, hopefully someone else posted or try your software install. Hope you get it working.
SOURCE: I have problem with my scanner. when I want
Ok but its saying to check your usb cable and you need to check if both the pc and this scanner is plugged in with this usb cable and that the scanner has it's power plugged in too.
It could also mean that you did not properly install the drive or the drive is old and you need to replace it or update it.
Please let me know what happens after ok?
SOURCE: Canon Pixma MP198 error code 2 114 0
i got a same prob..i can't print,scan and copy and the refill warning always appeared..i hv refill the cartridge and i shut it down and try again and again..it's the cartridge prob or the printer prob..?
