IN YOUR NOKIA 6120C ONLY 42 MB PHONE MEMMORY FIRST GO TO MESSAGES>OPTIONS>SETTINGS>OTHER>MEMMORY IN USE>MEMMORY CARD THEN YOU CAN SEND LARGE FILES TO YOUR MEMMEORY CARD IF DON;T HAVE MEMMORY CARD DELETE SOME DATA FROM PHONE MEMORY PLEASE VOTE IF YOU SATISFAID
No that's not likely the problem. The new card is probably the issue, especially if it is 4GB or higher. There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
you could run the check disk utility click start run type cmd then type chkdsk/r/f which willscan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
Try this link (click here). It's a winzip file of about 13 mb size. If you have problem let me know. I'll give you another link. Don't forget to include the O.S (operating system) name with your reply.
Scan the memory with latest antivirus. Download R-Studio with its serial. R-studio is an extraction tool. Extract all the files in your memory. And format the memory. Copy the files again in your phone memory
available physical memmory is what all your programs on your comp is using like windows virus software drivers im thinking you probably have spyware or bugs in your comp that could be bringing memmory down
MOTHERBOARDS
does my motherboard support video cards like
ATI RADEON X1650 512MB AGP?
---YES, When you installing AGP card, please make sure the following notice is fully understood and practiced. If your AGP card has
"AGP 4X/8X (1.5V) notch"(show below), please make sure your AGP card is AGP 4X/8X (1.5V).
Caution: AGP 2X card is not supported by Intel® 845(GE/PE) / 845(G) / 850(E) / E7205 / 865(G/PE/P) / 875P. You might experience system
unable to boot up normally. Please insert an AGP 4X/8X card.
Does it support ddr2 or ddr3 memmory for the agp?
---YES, see the above notes
can the agp memmory be over 512 mb?
More more information go here >>>
http://asia.giga-byte.com/FileList/Manual/motherboard_manual_8ipe1000g_e.pdf
Hope This Helps
If you are having trouble with a Newly bought items then return them and demand a replacement or a refund!
You may have purchased a reconditioned\repaired\factory defect product.
