How do i reset after battery change
You need to open the watch and cortocircuit 2 points into the watch machine.
TicTacArea.com is Officla Casio Dealer
Casio Watches
SOURCE: REPLACEMENT STRAPS
Call Casio Parts dept and they should be able to send you a band. 800-223-2001 is their number. :)
SOURCE: Casio SPF70 Spring Pins
The best way is to take a look on ebay. The only downside is: you have to buy a whole lot (I mean - you can not buy just a two or three springpins). Go to ebay, choose jewellery and watches and then watch parts and tools or accesories.
The other way is to try to find on internet jewellery and watch part supplyers in your coutry and contact them. They usually selling springpins in packs of 10.
Before you buy any of them, you need to measure the distance between watch case lugs in milimeters. The size between lugs is the exact size for the springpins to order.
If you are not happy with that, then you have to try to continue to visit more jewellers till you find the right ones.
Don't forget to rate, please.
SOURCE: replace batteries on sea pathfinder
If you see no screws holding the contact (metal frame), that means the contact is clip-on. Take an eyeglass and examine all contact legs carefully- you will find out where it is clipped on. Use fine pointed tweezers to pull contact legs and undo it.
Rate, please.
SOURCE: after battery replacement of casio sea-pathfinder
If it has "AC" written on the module you may need to short between the AC point and + battery. Also check voltage of battery. It may just be too flat.
