My leisure bay spa will not heat at all and the tube stays cold. It stays at 80 degrees and go's down in temp. The heat light won't even cut on. Please help
This appears to be the sleep mode, which is a freeze protection mode. You need to get your owner manual out and change the mode to standard so it will heat.
if the spa does not heat up to 104 degrees then the temp sensor is what you are going to need. Are there error codes showing on the screen of the topside? You will need to know the model number of the control box or the model number of the heater tube in order to get the proper sensor.
You have a faulty spa pack. Sorry to be the bearer of bad news but it will cost you more than what the spa is worth to fix it. Since this post is from May of last year I'm sure you found that out already. If I'm correct give me an endorsement so people know that I can help them. Thanks!
