MANUAL DOES NOT HAVE DIRECTIONS ON HOW TO RECORD WITH THIS MODEL
Looks like a great brand with good features for the price.
SOURCE: VCR
In vcr you mean? try unpluging the electric cord for 1 hour
then plug it back up. it just might eject it out. mine did.
SOURCE: sony VHS model no: SLV-SE710G isn't recording now
Its hard to work out without looking at your cables. I assume the problem started when the freeview box got set up. I would guess that the aerial cable is now in the set top box instead of the vcr as the vcr sounds like it is unable to record when there's no signal (a common feature) so there shouldn't be a fault with the vcr,
just unplug the aerial from the set top box & plug it back into the vcr. Ch 1 2 3 4 should be back on vcr but set top box wont have any Ch.
most set top boxes have an aerial output, so you'll need another aerial cable, plug this into the aerial input on the vcr & ch 1 2 3 4 will be there but these will be analog (if your area has stopped analog transmission thats the prob rite there)
If you plug the matching cables from the set top box into L1 on vcr you'll be able to record digital tv as L1 use a signal from another tuner eg set top box, dvd player whereas the vcr channels 1 2 3 4 use the vcr's built in analog tuner. so it shouldn't be a biggie another cable should fix it,
Hope this is helpful, ask if you need more info
SOURCE: I need an instruction manual for a Sony SLV-200
You can try the Sony website at the following link.
http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=DOCS
But I could not find the SLV-200, but there were other versions that may work for you.
I hope that this helps you out.
asnowman
SOURCE: I need a manual for
Go to this in your web browser:
Enter your VCR model number in the box. Click CONTINUE. The next page has the link to download user guide in PDF format. Click on the link Operating Instructions to download manual.
SOURCE: instruction manual for sony slv se730 vcr
Have you tried the Sony Website? They often have free PDF's of them.
