Fault with main board. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
SOURCE: Samsung Plasma 52 inch flatscreen vintage 2004 - black line
Hi my name is Roety,
I can help you with your issue ,
If the line is present on all inputs, and effects the TV menu you most likely need a new screen.
You can try changing buffers, reseating cables.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
SOURCE: ive got a samsung plasma display which goes to
main power board may be bad or if there is flashing of the LED...contact samsung tech support
SOURCE: I have a Samsung 50" plasma HDTV, about 6 years
either backlight (flourescent bulb inside) or power supply for backlight went bad - if you have voltage meter you can check if there is voltage where bulb goes and if there is replace bulb or if no power you will need to trouble shoot power supply which is common thing to go bad on these sets.
it is usually not worth paying to get this fixed if it is power supply and you might be better off just getting new set - sorry i know that is not what you were hoping to hear but....
good luck!!
SOURCE: I HAVE THIS( MODEL PN42C450B1D SAMSUNG PLASMA TV
If you cant afford to fix this problem I would be interested in buying this tv from you because i need a screen for it you can email me at [email protected]
