SOURCE: I can't figure out how to set the self timer from
For the SX 110 IS 9 mp camera: With the camera in picture taking mode, Hold the bottom of the roller dial down at the point closet to the timer icon. Hold it for a couple seconds, then the screen will display the timer settings. Select the setting you want and start taking pictures.
SOURCE: how do i set the timer on my canon powershot a560
There's a button with a clock next to it. Press that button and put your camera where you want it. Press the shutter release half way, to get focused. When you press it the whole way down, the timer will start and you will have 8-10 seconds. There is normally a burst of a few flashes when it takes the picture.
SOURCE: LCD screen not working
Hello
Ok, you should know that there is a cable which connects the lcd monoitor to the circuitboard of the camera itself. it could be that the cable is just slightly pulled out.
I know that there is a setting as well which enables you to use either the viewfinder or the lcd. Look for a button which looks like a screen with a star in it, this will either activate the lcd or the viewfinder.
At the link below you will be able to download the manual for this camera for further troubleshooting.
http://www.retrevo.com/support/Canon-SX10-IS-Digital-Cameras-manual/id/23007dj392/t/2/
Hope this can be helpfull.
Kind regards
Andrea
SOURCE: how do you unlock the memory card on a canon powershot SX10is?
Remove the SD card from the camera. Slide the tiny switch on the side of the card to its other "unlocked" position. Reinsert the card in the camera. But if you've already tried this, see this link for additional things that you can try.
SOURCE: where can we buy a broken lense on a canon
You want a broken lens or a replacement lens? Try: camerasandparts.com since they stock all of the powershot parts. They're amazing if you need help with one of these, I believe you can even have them install the lens if need be and they service the powershots too. Good luck, that's the place if you need help with a powershot, that's all they specialize in. Best of luck
