I have seriously overcooked my cordless circular saw and it has seized I need to dismantle it to diagnose what part is shot, how do I do it
This parts diagram may help.
Makita BSS610 Circular Saw Parts
SOURCE: Problem finding blade choices for Makita circular saw
OK done some more checking and I believe you are out of luck, but before giving up hope do you have a saw sharpening business in your area?? My friend says that he has sent blades to one in my area and had the center hole bored out to the appropriate arbor hole and the blades run true and from what he tells me it is relatively cheap, so check first and see and then you can buy a blade in the diameter you want and have it bored out. Sorrry I couldn't come up with anything else, I check about 6 diffferent mfrs and they all have the same.
SOURCE: I cannot get a perfect 45 degree angle with my
When using the gauge on your saw it is off on the 45 degree cut? If so you might have to use a tri Square every time you want to cut a 45. Sometimes the lock gauge for the 45 angle may be off some. When you put a tri square on the board you cut it is not a true 45 even though the saw says it is?
SOURCE: The return spring for the blade guard on my Makita
there should be a hole in the housing towards the back of the saw, you can go to Makitatools.com and download a breakdown for this tool.
SOURCE: how to get motor out of houseing on a makita 5007MG circular saw
The armature and field will need to come out. It's quite a bit of work to swap everything over. Here is a parts diagram which should help.
Makita 5007MG diagram
SOURCE: How come my lithium 18v battery (194205-3) wont fit on my new Makita 6 1/2 circular saw?
I sell & repair the Makita line of tools and the BL1830 (194205-3) battery is designed to fit on Makita's entire line of 18-volt tools. You didn't give the model number of your saw so my best suggestion is to make sure the saw is an 18-volt tool then make sure the tool's and battery's mating surfaces are OK. Try the battery in other tools & try other batteries on the saw. If this doesn't help please respond with the saw's model number or what you found out doing what I've suggested.
