When I plug my deep fryer into the outlet I am not getting a green power light and the heating elements are not getting hot. the reset set button is not working also. i check the cord and it was getting full power.
SOURCE: WOlfgang Puck Deep Fryer 1500 watts power cord
Hi - The 1700 watt fryer uses a magnetic release cord set type TA 35 P. If your unit says "use only with TA HSING CORD SET TYPE TA 35P, It should work.
SOURCE: Waring DF200 Pro - Power Cord Needed
Hard wire this piece of junk! Problem solved w/ mine !!
SOURCE: magnetic breakaway power cord for rival deep fryer
I have a Rival CF-250 cool touch deep fryer. Where do I get the magnetic breakaway power cord, filters, and filter cover.
Please let me know.
Thanks.
Ken Cooley
SOURCE: power cord for deep fryer
WHERE CAN I FIND A PL1215 POWER CORD FOR A COOL TOUCH DEEP FRYER MODEL#V090080196
Hi, Its very possible that you have the wrong power to your fryer. I noticed that you said that you tried to plug it in. If it does not seem to fit or if you had to bend anything on the plug to make it fit you need to have an electrician check to make sure you have the correct power to the fryer. The wall outlet will have the power information printed on it. The manual will give you the power requirements. It the plug fits ok, check your breaker for that outlet. Good Luck. If this solution does not rate an (Almost There) Please do not rate.
Thank You,
kstfas
