Question about D-Link Wireless N 750 Dual Band Router DIR-835
My n750db wireless n + router suddenly no wi fi
It was working fine, suddenly no wi fi
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 70 Answers
Unplug the router's AC power adapter for 5 minutes to ensure all capacitors have drained. Plug it back in and the router will reboot.
If your wireless doesn't start working. Log in to your router and check your wireless settings
Posted on Sep 28, 2014
2 Suggested Answers
SOURCE:
  • 192 Answers
SOURCE: my d-link 2640t wireless router suddenly no Wi-Fi
This one can be one of two things.
If you have a digital multimeter, check the power connection and make sure that it's not to high (eg. 7.5 V DC should read no more than 7.8 V for it to work properly)
Otherwise, just reset the router. I have a feeling it is the first one.
Once it reaches to 130% above of what's rated, it can fry your network adapter in your computer and possibly more damage if it's wired.
Posted on Aug 09, 2009
Carnot connect to wifi
Make sure the router is working as it should.
Mar 19, 2017 | Cell Phones
Why won't my TV connect to my woreless network?
You need to check whether there were changes made in the Wi-Fi setting of your TV including the password, method of protection, SSID etc. matching to your Wi-Fi router settings.
Jul 20, 2014 | LG Electronics 37CS560 37" 1080p LCD TV -...
Wi-fi connection gets disconnected frequently and reconnects by itself. Tried to reinstall the wi-fi drivers but no improvement. The same laptop is working perfectly at another wi-fi environment.Tried to...
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls, mirrors, fish tanks and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Apr 01, 2013 | Computers & Internet
I have a Netgear DG834G v4. Wireless connection is fine, ISP is fine and Internet via wireless is perfect. Nothing via the LAn ports seems to work. Both XP and Win 7 machines see Lan as an undefined...
DHCP SERVER in Router and DHCP server in Wireless Conflicting - Set WI Fi DHCP router leases to say 192.168.0.10 to 192.168.0.100 and default gateway as 192.168.0.1 and on the router set the router's ip address to 192.168.0.1 make the Wi Fi router address 192,168.0.2 . Set in the router the DHCP address leases to 192.168.0.101 - 192.168.0.254 and default gateway 192.168.0.1 or deactivate one of the dhcp servers and rely on one dhcp server like the routers and then deactivate the wi fi's dhcp server.
Jul 28, 2017 | NetGear DG834G 54 Mbps 802.11g Wireless...
I have wireless - router with built in dsl modem DGN2000. Working fine with my desktop but I have just purchased a laptop and have not been able to connect signal to it.
1. Dear! Check your notebook wireless settings and correct it if it is necessory.
2. Chekc your wireless router settings may it need to update for your notebook.
Good Luck
Sep 28, 2009 | Computers & Internet
Changing Wireless network password without resetting the router
For that access your router with
http://192.168.1.1
or http://192.168.0.1
if you cant able access it then reset it
Press RESET button for 10 seconds it is in back sid of router.
then access above link.
type user name "admin' and password as "admin' or blank or "password'
then go to wi fi security first configure your router as WEP then go to wi fi security in advancwed then set WEP key it is your password to connect wi fi .
Aug 13, 2009 | D-Link 802.11g Wireless Router WBR-1310...
My d-link 2640t wireless router suddenly no Wi-Fi
Aug 09, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Connect Additional Computers to my network
ok
first install your wi fi network adapter driver in computer also if you have laptop then there is switch for wi fi on it.
Then go to my ntwork polaces there you see your wi fi network.
Also check your wi fi enabled in router .
Let me know
Jun 23, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Failure of wi fi connection
Go to manage connections and check wi fi is turned on and scan for the available network.and connect to your net work.(also make sure your wireless router is working fine)
Feb 27, 2009 | RIM BlackBerry Pearl 8120 Cellular Phone
Hi, I have an old acer laptop and my wife communicates with me on it using broadband and a router with a usb pick up. I have returned home and have a new acer laptop with wireless LAN already installed. It...
Youe broadband router is working ok with the broadband cable.So it is configured with the broadband cable.Now,to work with the wireless internet,you have to configured the wi-fi router to work internet.You can see the wi-fi connection but unless & untill you will configure wi-fi router it must not work or if before it was working with the wi-fi then you can check the wi-fi router setting because it might change by mistake.Surely it will work after configurating wi-fi router.
Jan 03, 2009 | Computers & Internet
Open Questions:
See all D-Link Wireless N 750 Dual Band Router DIR-835 Questions
D-Link Wireless N 750 Dual Band Router DIR-835 Logo
88 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
