Question about Konica Minolta Office Equipment & Supplies
How to solve error c0650 on minolta di2510
The machine bring out error code c0650 and i trying to change home motor censer but still not working. i need help from any one has faced this problem before. thnk
  • 210 Answers
Did you changed the home sensor? If yes, is the sensor working properly? Try the sensor function in Service Mode.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Posted on Aug 21, 2014
SOURCE:
  • 87 Answers
SOURCE: minolta dialta trouble code c0650
C0650 .THIS CODE IS FOR SCAN MOTOR OR SCAN SENSOR PRBLEM.JUST CLEAN SENSOR OR CHECK SCAN MOTOR IN OPTICAL UNIT.MAY BE MOTOR HAS PROBLEM.BY MIAN JEE
Posted on Dec 18, 2008
  • 11 Answers
SOURCE: Kinoca Minolta Di2510 Double-sided printing
Yes it can be done, if the m/c is having duplex unit.
Posted on Aug 17, 2009
faeq8
  • 7 Answers
SOURCE: Minolta DiALTA Di250
C0650: Faulty PC12 C0651: Faulty PC13
Relevant Electrical Parts Scanner Home Position Sensor 1 PC12 Scanner Home Position Sensor 2 PC13 Scanner Motor M5 Master Board PWB-A BCR Board BCR HGB Board HGB MFB Board UN2
Posted on Dec 28, 2008
SOURCE: minolta di251 c0650 code
Our machines is giving us this error code# C0650
Can we fix it!!
Posted on Sep 12, 2009
  • 170 Answers
SOURCE: Konica Minolta Di2510 error code C0500,can not
check the fusing unit parts heaterlamp,thermistor & thermoswitch i'm sure one of them is the cause of error c0500
Posted on Nov 22, 2010
Service call C0650
Error code C0650 Konica Minolta bizhub 160 Black
Faulty scanner home
position sensor.
• The scanner home position sensor (PS100) does not go
from HIGH to LOW when the scanner motor (M4) is energized
for a given number of steps after the sequence to
bring the scanner back to its home position has been
started at the end of a scan motion and during re-shading.
from LOW to HIGH when the scanner motor (M4) is energized
for a given number of steps after a scan motion has
been started at the end of a PS100 home check scan
THANK'S
Jun 26, 2013 | Konica Minolta bizhub 160 Black Drum...
Error code c0650
Is 2 home sensors.Try reset the code.
Mar 01, 2013 | Konica Minolta bizhub Office Equipment &...
REMEDY TO SOLVING ERRORS COF32 AND CO650 IN KONICA MINOLTA BIZHUB 211.
C0650 code is the scanner lamp home sensor is not working so the copier does not know where the scanner is clean first will require removal of the orginal glass (large one) the other code is the image unit, has it been replaced or repaired recently. To fix mite require a new image unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 17, 2010 | Office Equipment & Supplies
How to solve bizhub 211 code error c0650
bizhub 211 error code C0F32, To solve this code simply replace the developer of the machine.
Feb 17, 2010 | Konica Minolta bizhub C250 All-In-One...
Minolta di251 c0650 code
Hello sir; This problem caused by home positon senser problem, replace it.
Aug 25, 2009 | Konica Minolta Office Equipment & Supplies
Minolta Di 1610 f not starting
Scanner home position. Check the scanner itself there is a small piece of plastic that actuates the home sensor, check for dust dirt (can air) sensor is loacated under the glass left side rear
Apr 27, 2009 | Office Equipment & Supplies
C-0500 code on bizHub 163
ARE YOU CONNECTED TO A LAN CARD OR NETWORK OF ANYKIND.
GO ON LINE AND TYPE IN
MINOLTA DI2510 B/W COPIER C-0500 ERROR MESSAGE
ENTER
ROD
Feb 05, 2009 | Minolta DI2510 Black and White Copier
Nov 06, 2008 | Minolta DiALTA Di250 All-In-One Laser...
Minolta dialta trouble code c0650
Oct 23, 2008 | Office Equipment & Supplies
ERROR CODE C0660
This is a scanner problem, try the following...
C0650, C0660
Step Check Item Result Action
1 Scanner can be moved manually.
NO Correct drive coupling (Scanner
Belt tension, pulley operation,
drive cable tension)
2 Scan motion: initial scan motion after the
Power Switch has been turned ON or Front
Door has been opened and closed.
NO Carry out misfeed/malfunction
troubleshooting procedures.
3 Connectors are connected properly on
Scanner Motor Drive Board: PWB-IC
PJ1IC, PJ2IC, and PJ3IC.
NO Check connectors for connection.
4 Scanner Motor turns when the Start key is
pressed.
Change motor. Change
Scanner Motor Drive Board.
5 I/O check for Scanner Home Sensor: the
voltage across PJ6C-2 on Image Processing
Board and GND is DC 0 V (home position)
when the sensor is blocked and DC 5
V when the sensor is unblocked.
YES Change Image Processing
Board.
NO Check sensor for installation.
Correct detecting plate.
Check sensor connector for
connection. Change sensor.
6 “IR Area” check:
Malfunction when Power Switch is turned
ON after “Top Image” has been set to 0 and
“FD-Mag.” to 1.000.
Apr 03, 2008 | Minolta CF2001 Copier
287 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
