Get the unlock code for Huawei y530-u051 phone to use any network SIM. Here is the direct link to get the unlock code with in simple steps.
Just follow the link below- https://www.unlockninja.com/unlock-huawei+y530-u051
-Select Country
-Select Network
-Update IMEI
Get the unlock code directly to your mailbox by unlockninja
#huaweiunlockcode
This can happen for a number of reasons. You could have a virus on the device, the operating system could be crashed, there could be a hardware glitch.
I would start with attempting to boot the phone into recovery mode. You can follow the steps attached to do so. Once you get into recovery mode, try to select the option that says "Clean System Cache" and then reboot the phone.
if you have tried to unlock you phone by inserting the wrong pin ( personal identification number) number more than 3 times , the service provider automatically blocks the phone by removing the PUK code ( personal user key)
if that is the case contact your service provider on another phone , provide proof that you own the account for the phone and they will give it to you once that is done you can enter a new PIN number and it should work
Write the number down where you will not forget it
Try this instead:
connect your phone to the computer with the given USB cable.
Open my computer and look for your phone. It should be listed. double click to open and look for DCIM folder and the pictures in that folder. If you find that, just copy and paste in the folder of your choice.
you can also connect the phone with the cable and a window should pop up asking what do you want to do. Click on import pictures and the rest is as per instruction on the screen.
Hope it helps Huawei Ascend Y530 setup and user guide
Hi. If you're pertaining to the touchpad of your laptop then Yes, you can disable it or turn it off by pressing Function(Fn)+F8 button. Hope this Helps
