Sanyo SR-4910M Compact Refrigerator Logo
A
Anonymous Posted on Aug 18, 2014
Hi! How do I find Sanyo compact ice storage replacement door? Thanks!
Ice Storage door
gregmk
Level 2:
Sergeant:
  • Expert 204 Answers
  • Posted on Aug 18, 2014
gregmk
Expert
Level 2:
Sergeant:
Answers
204
Questions
0
Helped
86321
Points
896
I'm assuming that your asking about a freezer door on a compact refrigerator. parts can be ordered on line @ sears direct, go to link below & enter model # or scroll down page & select refrigerators under, find parts by top product categories - scroll to refrigerator brands found - select Sanyo refrigerator parts - scroll down & select your model - select View all parts in this diagram, some parts will be available others you will have to call phone # provided. when looking @ your parts list there will be a exploded view on left ( to see it better click on view full size) http://www.searspartsdirect.com/partsdirect/brands-products/Sanyo-Parts/Refrigerator-Parts
2 Related Answers
Anonymous
  • Posted on Mar 25, 2009
SOURCE: Where to buy Sanyo SR-366 parts? I need a freezer door.
I will probably have one, I'll look to see if it can easily be removed.
Anonymous
  • 2341 Answers
  • Posted on Aug 27, 2011
SOURCE: I have a Sanyo Compact
No its dead the gas was the freon and it will not get cold
Kenmore refrig model # 10645423801 cannot remove ice storage bin
Could it be frozen in? If so, u may have bad door seal or ice door seal is not shutting properly.
1helpful
Can i remove the ice storage compartment from the sanyo 4433s and still use the refrigerator
Probably, provided that it's a storage module only. If it's an integral part of the ice production function I would say probably not. I searched "sanyo 4433s operation manual" & got a number of hits. Try manualowl.com & retrevo.com.
1helpful
Ice maker not dropping ice
Need more info. Are there ice cubes in the storage section just behind the freezer door? You may have turned the ice-maker OFF. When your depress the ice flipper, does the motor run behind the door? The motor may be burned out or the ice cubes in the storage section are so melted together in a giant glob that the agitator cannot turn.Or, maybe someone turned OFF the water supply.
Ice not dispensing from door. There is ice in the cabinet.
look behind the ice storage bin---there is a c-bracket that the storage bin slides into --- the motor may have to be replaced that turns the spiral feeder inside of the storage bin
The part where you would press to get ice, well up in side is not releasing the ice and closing back
On mine, using crushed ice will cuase a build up of ice along the shoot. I take off the storage bin and manually open the door cleanining out the shoot. Make sure to check under the removed storage bin before replacing.
1helpful
FROST BUILD UP ON ICE STORAGE BIN AND INSIDE OF
Most times this is caused by the dispenser door not shutting all the way. This causes moist air to be drawn in through the opening and the moisture will freeze in that area and also cause the dispenser door to have even more problems closing. Check the door and get me your model number so I can list the parts that are most likely causing this, Thanks Sea Breeze
I have model 3XART720F02 ART706 TYPE 2055A The water ice distribution area needs cleaning. Can this area be dismanteled
Prepare the Ice Maker For Cleaning
Step1Lift the power located above the ice maker storage tray.
Step2Unplug the refrigerator.
Step3Allow the refrigerator and to defrost. This will melt any large blocks of ice that have accumulated in the ice maker
Clean the Ice Machine
Step1Remove the ice machine storage tray.
Step2Dump any water in the ice machine storage tray.
Step3Wash the ice machine storage tray using warm, soapy water. Rinse and allow to dry completely.
Step4Sanitize the lines of the ice maker. Consult your manufacturer's
directions for steps to do this, because it's not available on all models.
Reassemble the Ice Maker
Step1Replace the ice machine storage tray.
Step2Plug the refrigerator into the outlet to restore power.
Step3Lower the internal power bar located just above the ice machine storage tray. This allows the ice machine to make new ice.
How to Clean an Ice Maker
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
[email protected]
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
4helpful
2answers
KitchenAid Fridge, Ice maker not working - red light blinking
Replace the icemaker . The laser receiver (on right side ) is supposed to blink twice then pause then twice repeatedly .Normal. Also clean the coils under fridge .
2helpful
Sub zero particles in ice from ice maker
This issue occurs if your Ice Maker is not clean or have dust particals inside, follow the below steps in order to clean it properly:
Step 1 Lift the power bar located above the ice maker storage tray.
  • Step 2 Unplug the refrigerator.
  • Step 3 Allow the refrigerator and freezer to defrost. This will melt any large blocks of ice that have accumulated in the ice maker.
  • Step 1 Remove the ice machine storage tray.
  • Step 2 Dump any water in the ice machine storage tray.
  • Step 3 Wash the ice machine storage tray using warm, soapy water. Rinse and allow to dry completely.
  • Step 4 Sanitize the lines of the ice maker. Consult your manufacturer's directions for steps to do this, because it's not available on all models.
  • Step 1 Replace the ice machine storage tray.
  • Step 2 Plug the refrigerator into the outlet to restore power.
  • Step 3 Lower the internal power bar located just above the ice machine storage tray. This allows the ice machine to make new ice.
  • 2helpful
    My icemaker is not making ice. This has happened 3 times in the past 3 years but this is the longest it has gone without making ice. The other 2 times it lasted 2 days. It has now been 4 daysince the ice...
    Check the following:
     Is the freezer door closed completely?
     Is the ice storage bin installed correctly?
     Is there ice in the storage bin?
     Has the ice frozen in the storage bin?
     Is ice stuck in the delivery chute?
     Has the wrong ice been added to the storage bin? Use only
    cubes produced by the current ice maker.
     Has the ice melted around the auger (metal spiral) in the
    ice bucket?
    Dump the ice cubes and clean the ice storage
    bin.
     Is the ice dispenser stalling while dispensing “crushed”
    ice?
    Change the ice button from “crushed” to “cubed.” If
    cubed ice dispenses correctly, depress the button for
    “crushed” ice and begin dispensing again.
     Has the dispenser arm been held in too long? Ice will stop
    dispensing when the arm is held in too long. Wait 3 minutes
    for dispenser motor to reset before using again.
    Top Sanyo Refrigerators Experts
    NOEL
    NOEL
    john h
    Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
