I just addressed a iCO error code on my 2 week old Frigidaire Gallery DW. I reset the circuit breaker as recommended online and it worked fine for another few days and then came back. Customer service cannot tell me what the error code means. They WILL NOT replace the DW, rather want to schedule a service appointment. I have no desire to repair a new DW so I am receiving a refund from the retailer I purchased from. On to the next brand!
Resetting the DW by flipping the breaker worked. Thanks!
Good afternoon friend, I appreciate your post!
I see you are having trouble with the self-cleaning feature on your Frigidaire range and you are receiving error code "iCO". However, it appears "iCO" is an invalid error code. You question is labeled under model FGHD2465NF, could you verify that is the correct model? In the meantime, let's attempt resetting your dishwasher. You can do this by flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your dishwasher continues to display "iCO". I look forward to assisting you. -Matt
SOURCE: I have this code error
That will be a main control board. Also if you have a touch pad replace that also. If its more than three years do not repair but replace.
SOURCE: i have a frigidaire dishwasher gallery water is on
Hi
Thanks
for using FixYa. To start with check the water inlet valve which is located
behind the lower access panel on the left or right side of the Dishwasher. If
the water inlet valve is bad you have to replace it, also check the main water
line for clogs/obstructions. If still the issue is not resolved then it’s a bad
float switch and needs to be replaced. Please do rate the solution if the
issue is resolved or post a comment for further assistance.
Thanks
Rylee
Reset it at the household circuit breaker for about 10-15 minutes, and retry.
I appreciate your post, friend!
From what you have described your Electrolux dishwasher is displaying an error code of "iCO". That error code describes a communication error within your dishwasher. The best way to correct this issue is to disconnect power for roughly ten minutes and you can do that by flipping your household circuit breaker off. If you continue to have issues with an "iCO" code I would suggest it could be a problem with your control panel or wiring harness and you may want to have a technician come out to perform a diagnosis on your dishwasher. This will help you to avoid any unnecessary part purchases. -Matt
Good Morning Jimpat Holmes, thank you for your inquiry!
I understand that you are having an error code "ER" displayed on the panel of your Frigidaire dishwasher. Normally, "ER" stands for error code and that can be a miscommunication within the board. I would perform a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for ten minutes. If you continue to receive an error code you could be experiencing an issue within the control panel or faulty wiring harness. I hope this information is helpful. -Matt
Hi friend, thank you for your inquiry!
I understand that the panel on your Frigidaire dishwasher has lights on the far right side of the panel. I would recommend a reset on your dishwasher and you can do that by flipping the household circuit breaker in the off position for ten minutes. The lights on the right side of the panel could be providing a warning to inform the panel that something is wrong. A reset could provide an error code for further diagnosis. I hope this information has been helpful. -Matt
I am having problems with it continuously running and not cycling... the only way I can cut it off is to turn off the breaker
